Qustion
Old May 15, 2006 | 03:29 PM
quick_baltss's Avatar
Question Qustion
What type of gains would I be looking at with only a intake, exhaust, and a 3.0'' pulley.
Old May 15, 2006 | 04:09 PM
Mercury's Avatar
Intake: 5-10 whp
Cat back exhaust: 2-5 whp
3" pulley 10-25 whp
Old May 16, 2006 | 12:23 AM
One more question for you all then I'm threw. What is the smallest pulley you can use with stock injectors and one step colder plugs, is it a 2.9'', 3.0'', or a 3.15''? I would really love to use the 2.9 but I don't know.
Old May 16, 2006 | 01:06 AM
cashstacker's Avatar
Well I'm not sure about what size pulley you need injectors at but I believe if you go smaller than 3 you will need a way to adjust your air/fuel ratio.
Old May 16, 2006 | 01:11 AM
VictoryRed06's Avatar
2.8 is the lowest u can go without blowing ur motor. but its right on the line.
Old May 16, 2006 | 01:36 AM
is that with stock injectors and stock a/f?
Old May 16, 2006 | 01:54 AM
Saki XL's Avatar
Personal matter of opinion.. You're going to be running lean on 2.8 inch pulley without control over the A/F ratios (i.e. a MAF Translator or Tuning of some sort..) -- you might as well upgrade the injectors to 42.5 lbs/hr if you're dropping more than 3.0''. Honestly, I would rather run a tad rich than too lean. Matter of my opinion though.. You can get some injectors for sale as well! A few guys on here have directed me toward some, I don't know if they're still available though..
Are you just not able to afford the injectors right now, or does the Delphi strike affect your purchasing as well? (I had this problem for about 2 days... trust me.. it sucks.)
~Saki
Old May 16, 2006 | 02:00 AM
with stock injectors thats the lowest u can run apparently but i dont think anyone has done it beside some redlines.
Old May 16, 2006 | 02:16 AM
NJHK's Avatar
Injector sizing has less to do with adjusting your air/fuel ratio, more about being able to supply fuel to it's demand. Adjusting the a/f ratio from stock is done by your computer...they designed your cars computer to read boost (utililzing a 2.5 bar TMAP sensor) and to comphensate fuel properly during boost.
With that said, going to a smaller pulley (generating more boost) and not reflashing the computer (your controller of how much fuel you get) to supply the right amount of fuel and keep your a/f ratio level steady throughout boost & RPMs isn't a good idea.
This is why GM PURPOSELY has Stage Kits that include: Smaller Pulley, a reflash and bigger injectors. The reflash (like said) is for adjusting the your a/f ratio properly and also to work properly with bigger injectors, not just under boost but even at idle (turns the duty cycle down on your injectors so you can idle properly).
Everything works hand and hand. I've said this before in another post...if GM has specific upgrade kits for your application so you can make more power, BUY IT! This will ensure that you're doing it properly or won't encounter any problems and you're still leaving GM as the Engineer (technically).
Old May 16, 2006 | 09:48 PM
So it's okay to run a 2.9'' pulley with the boost mod and intake and exhaust.
Old May 16, 2006 | 10:04 PM
l Sh1ft l's Avatar
What size injectors do you get w/ the stage 2 kit?
Old May 17, 2006 | 09:04 AM
NJHK's Avatar
Ideally, yes, but make sure if you're upgrading your pulley to get the kit, not just the pulley.
Old May 17, 2006 | 07:15 PM
Floridas Finest SS's Avatar
If you got to Intenseracing.com and look at there Pulleys they reccommend how low u can go without screwing up your car.
MrSlickSter06SS
Mar 19, 2010 06:30 PM
07MetallicSC
Jan 23, 2010 12:05 PM
kissrocker52
Sep 4, 2009 07:56 PM
jc1997cav
Jul 11, 2009 05:22 PM
