Rebel Build
Old Aug 25, 2008 | 06:57 PM
  #76
Area47's Avatar
Rent me! per hour
keep tryin! you'll blow it up good!
Old Aug 25, 2008 | 09:22 PM
  #77
Sales@rebelautoworxs's Avatar
Originally Posted by Area47
you're missing the slight variations in there.
the rpm = changed for a reason.
max power was read off a spike at 6500.
im really trying not to discredit anyone here. this is something that is really hard to swallow
The RPM and AFR was cut off of the stock dyno because everyone already knows how rich it runs stock.
Originally Posted by freakta
well what was the reading before the spike, and why didnt they run it to 7k like the stock dyno run, amd if it was a spike of 10hp then who cares its still 40hp over stock
Both runs were done to 6500 to keep the results more comparable. Yes we could have run to 7000 but then there would be people bitching because we didnt use the same RPM.
Originally Posted by djt81185
Also in the stock dyno something pulled a lot of timing starting at what looks to be 5500rpm (cant tell cause no rpm on graph) Im not sure on its affect on peak but notice the dip at 5500rpm isnt there on their after graph. And being the tunes were supposed to be the same...
The stock run ran well below 10 afr on the tail pipe sniffer thats why there is such a loss in power in the mid 5000's. After the mods the AFR came up to around 10.8 buy the top end but was running to lean until around 5000 so the afr was tuned because you dont do such extensive mods and not tune for it. Theh owner drives this car hard and we dont need it blowing up on him.
Old Aug 25, 2008 | 09:29 PM
  #78
ralliartist's Avatar
well, sounds like you guys are on to something, care to enlighten us, or just me?
ahhh, there's the gain, changing the tune.
Last edited by ralliartist; Aug 25, 2008 at 09:29 PM. Reason: Automerged Doublepost
Old Aug 25, 2008 | 09:36 PM
  #79
INFE's Avatar
I would not mind a ported head from you guys but i dont want a month or more in down time waiting for the head to get back. I drive this car everyday.
Old Aug 25, 2008 | 09:42 PM
  #80
We have a head ready to be shipped to the machine shop so if you buy one you will have the new head sent to you and then you will send back your old for a core exchange. So it can be done in as little as 2 days. It could be done on a weekend if you are good to do it your self but I would not recomend this for a novice. A good shop could probly do it in 1 day.
Old Aug 26, 2008 | 12:20 AM
  #81
Eng@RebelAutoWorxs's Avatar
the test were on the exact same dyno, same SAE corrections.
Yes the HP numbers are spikes both stock and ported. I'll see if I can get a graph from the dyno overlaying both runs. The difference throughout the entire power is significant.
The only tuning we did was to account for the increase in air flow. Just fixed the air/fuel.
If you don't think our stock numbers were good, take a look at the GM Stage 2 sheet posted in the first post. Still 30WHP on top of GMS2. Every GMS2 we dyno'd ran those numbers +/- a few HP.
Flow Numbers:
Last edited by Eng@RebelAutoWorxs; Aug 26, 2008 at 12:21 AM. Reason: Automerged Doublepost
Old Aug 26, 2008 | 09:23 AM
  #82
Eddie's Avatar
wow over 100cfm increase on exhaust, and almost 100cfm increase on the intake, @550 lift. thats verry impressive. good flow numbers.
Old Aug 26, 2008 | 09:24 AM
  #83
Edubs's Avatar
Damn...
Time to pull the head off my car again!
Old Aug 26, 2008 | 11:01 AM
  #84
haha, you are looking at that chart wrong. It's a little over 40cfm increase intake and a little over 50cfm increase exhaust.
Still a lot though. But not over 100.
Old Aug 26, 2008 | 07:43 PM
  #85
burntorange's Avatar
all I know is that I want one, and as soon as I can come up with a way to pay for it you will have a pm
Old Aug 26, 2008 | 10:28 PM
  #86
rollingboostedss's Avatar
this sounds good, and you guys are a lil bit cheaper then JPB
Old Aug 26, 2008 | 10:47 PM
  #87
Tennpenn83's Avatar
click... just imagine the possibilities...
Old Aug 27, 2008 | 08:17 AM
  #88
qwikredline's Avatar
and better flow numbers dont neccessarily lead to more power/torque but the exhaust port is the cork in this motor...
Old Aug 27, 2008 | 09:07 AM
  #89
QFTT, I'm doing a mild port/polish to my head when I add all my new mods. Also porting the stock intake manifold. Stock exhaust ports are tiny though.
Old Aug 28, 2008 | 07:51 PM
  #90
so how many would be interested if we run a group buy on the head and beat up on our supplier for a really low price.
Old Aug 28, 2008 | 09:08 PM
  #91
selfinfliction's Avatar
are you using stock valve sizes and lift with that huge ass gain?
Old Aug 28, 2008 | 09:12 PM
  #92
Eddie's Avatar
ah ur right, damn it how did i miss that. crap such a noob mistake.
Old Aug 28, 2008 | 09:45 PM
  #93
theneelster's Avatar
GMPP has some heads with exhaust ported...700 bucks
Would have to be just the assembled (possibly unassembled) head for me to be interested. Don't need the exhaust, don't need the t/s.
IE
CNC port intake, exhaust and chambers
Diamond honed guides, valve job and deck skim
SI Valves Intake Valve - GM Ecotec - 36.1mm (+1mm)
SI Valves Exhaust Valve - GM Ecotec - 31.1mm (+1mm)
Ferrea GM Ecotec Titanium Retainer - use with S10057 valve spring
Ferrea GM Ecotec Dual Valvespring - 75lb on seat, 14mm max lift
GM Valve Seal - GM Ecotec
Head studs
Cosmetic Head Gasket
Even then...it's still may be cost prohibitive for me.
Last edited by theneelster; Aug 28, 2008 at 09:47 PM. Reason: Automerged Doublepost
Old Sep 1, 2008 | 01:40 PM
  #94
OriGinaL Condo's Avatar
Depends on the price but I'd definitely be interested
Old Sep 1, 2008 | 01:42 PM
  #95
Edubs's Avatar
Curious...
Old Oct 9, 2008 | 05:30 PM
  #96
Rippin07's Avatar
Any updates on this project or the cylinder head?
Old Oct 31, 2008 | 02:13 PM
  #97
freakta's Avatar
ya any update?
Old Nov 1, 2008 | 11:06 PM
  #98
waiting to get the car back for the TS install, customer is in school at the moment
ineedacobaltss
Nov 7, 2015 02:25 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
patooyee
Oct 15, 2015 05:11 PM
