The REDLINE lives!!!!
Old Aug 31, 2008 | 06:07 PM
  #51
csementuh's Avatar
Originally Posted by Witt
Pro ******* engine build imo.
Nothing like 25-30psi on break-in.
Witt & WSFrazier Engine Services looking for another project.
If I ever feel like spending the money, I'll do pistons, studs, cams, valve springs, etc...
Old Aug 31, 2008 | 06:08 PM
  #52
WSFrazier's Avatar
IMO, we should start charging people... Unless we like em of course.
Old Aug 31, 2008 | 06:09 PM
  #53
Witt's Avatar
Dan would owe us a lot of money.
Old Aug 31, 2008 | 06:12 PM
  #54
WSFrazier's Avatar
i see wut u did thar
Old Aug 31, 2008 | 06:58 PM
  #55
ItalianJoe1's Avatar
What would it cost for a full shortblock build, assuming I supply all the parts?
Fully balanced and all that good ****.
Old Aug 31, 2008 | 07:41 PM
  #56
Area47's Avatar
Rent me! per hour
oooooooooohhhhhhhhhhhhhhhhhhhhhhhhhhhhh
snapple
Old Aug 31, 2008 | 07:48 PM
  #57
SSdan's Avatar
Ive been trying to recruit one of you for mine, I keep getting the cold shoulder though. :shrugs:
Old Aug 31, 2008 | 07:55 PM
  #58
camarokiller's Avatar
Im gonna have to come up to the burg the next time you guys have a meet or something.
Old Aug 31, 2008 | 08:27 PM
  #59
djt81185's Avatar
LOL there was no balancing on my build...unless the machine shop did it.
Tho it does run good...so far
Old Aug 31, 2008 | 08:31 PM
  #60
Well, if I do one, I wanna do it right. I'm not gonna build a motor for this car twice...
Old Aug 31, 2008 | 08:33 PM
  #61
WSFrazier's Avatar
Machine shop just did cleaning and honing. Balancing not really needed on an I4.
  #62
djt81185's Avatar
There is really no balancing needed as long as all components are the same weight across the cylinders..cause that is how u balance a 4 cylinder
Old Aug 31, 2008 | 09:39 PM
  #63
Well, I learned something. I figured they were still balanced regually, crank weights and such. NM then
Old Sep 1, 2008 | 04:09 AM
  #64
hungryhip-ccp's Avatar
click.
Old Sep 1, 2008 | 09:57 AM
  #65
06blackg85ss's Avatar
sooooooooooo where's the vids lol.
I wanna hear what this thing sounds like mn
Old Sep 1, 2008 | 12:07 PM
  #66
djt81185's Avatar
Gotta get it back from getting the shifter cables replaced under warranty. It was getting close to dial in when they went
Old Sep 2, 2008 | 08:16 AM
  #67
PpAzZ1101's Avatar
Feels slow imo.
Old Sep 2, 2008 | 08:25 AM
  #68
06black's Avatar
dan-dan.
kinda-sorta read tho some of the first posts....
congrats on getting her back up an running bro, you gonna make it up to the Fall BBQ?
as for WG spring, I'd pack a 1bar / 1.1bar in there. i mean, do you honestly ever think your going to run LESS then 15psi?
the larger spring will help control accuracy, and help eliminate any spool loss from the gate cracking to early. (issue i had on my first WG)
also, I've had the 79's on my car for a while now, stock every thing on the fuel system, with no issues.
all though shes starting to run out of injector, so maybe over winter a fuel system will go in.
but this is with my 60-1, ported head, ect.
hope to see you around man, you back in flint-town yet?
Old Sep 2, 2008 | 08:28 AM
  #69
SSdan's Avatar
How you get shift cables replaced under warranty on a turbo swapped redline is beyond me.
Share your secrets
Old Sep 2, 2008 | 08:49 AM
  #70
Edubs's Avatar
The shift cables weren't changed, why shouldn't they replace them for him?
Old Sep 2, 2008 | 08:52 AM
  #71
Witt's Avatar
Share your secrets
Dan is very ummm..... persuasive.
Old Sep 2, 2008 | 09:33 AM
  #72
PpAzZ1101's Avatar
Free protein storage for the GM tech at Saturn of Monroeville.
  #73
Witt's Avatar
Wow, haha, or that.
Old Sep 2, 2008 | 12:06 PM
  #74
dan-dan.
damn just saw your numbers... .I need to get moving on some engine work here. lol
and all you need is a pump, should take up the slack of the stock one.
and 1-bar spring is the way to go, I had a .8 on there at first and it was giving me issues.
btw when did you switch to the 60-1?
Last edited by 06blackg85ss; Sep 2, 2008 at 12:06 PM. Reason: Automerged Doublepost
Old Sep 2, 2008 | 01:21 PM
  #75
06black's Avatar
yea, I'll pop my Bosh 040 in there and have more then enough pump.
i swaped to the 60-1 when i knew the 30R wouldn't cut it. i was pushing the PR to high for the 30R to deliver air flow, so the 60-1 became the best to use.
next is a 35R HTA, that'll come over winter.
