Replacing Thermostat?
it is almost easier to take the cam positioning sensor out and go from there but there are other ways....if you take the cps out make sure it goes back in exactly how it came out or your car will run like **** or maybe won't even start
Drain the fluid. Unbolt the three bolts from the top. I laid under the car to remove and reinstall the thermostat. Reinstall the three bolts. Fill the recovery bottle and start the car. Top it off occaisionally.
The thermostats in these cars seem to stick open around 60 to 75k miles. I've owned two SS's and they both stuck open somewhere in that mileage range.
wow didnt see this till after i did the job. ha. yea it was a pain. 3 bolts and 2 hrs of labor. had to have a friend hold the socket on while i loosened them. only about 3/5th quart of coolant spilled out when i did this, just missed both pans i had underneath -_-. lol i guess the previous owner changed it before and forgot the gasket of the old one in there cause i found that there was an extra gasket stuck holding the thermostat open!! it was really odd to find that in there...
Mine is also stuck open. It takes about 20 mins of driving for the car to warm up. I stuck a small piece of cardboard in front of part of the radiator last year during the cooold winter months to help a bit.
I tried replacing the t-stat about 2 years ago and gave up b/c I couldn't figure a way to get to the bolts...I must have been going about it the wrong way.
Hopefully somebody will post some good pics and a how-to on here soon....
I did it on my wifes 2.2...it wasnt that bad. Just have to remove 3x bolts and then the hose comes loose. you then pull out the old thermostat, and put the new one in...bolt the three back up. Done
Make sure you put something under the pipe cause a **** ton of coolant will flow out.
on the drivers side of the engine between the engine and the fuse box and your gonna get coolant everywhere so make sure you have stuff down to catch it in but its not hard but yeah you will have to do it from underneath the car
i dont know how u were able to see the top of the bolt heads from under the car if they face up. i just did my from the top. now im interested tho. ill have to get a look from that angle.
Same here. mines now stuck open. 2.0LSJ @65,400 miles. it usually runs around 157-160F occasionally i can get it up to 178 but thats if im sitting for awhile. if im cruising its bin around 160 for the past week or so. takes awhile to warm up. looks like im replacing my thermostat
agentirons
Oct 16, 2015 02:11 AM
DANRICKARD
Oct 1, 2015 12:08 AM
importkiller
Sep 30, 2015 07:18 PM
