Rough Idle
Is your throttle body clean?
(Fwiw, I have the same set-up with the same tune and have cleaned my throttle body/maf and have a stock intake and get idle bounce. A custom tune should eliminate it).
Joel
Joel
Find someone with HPT to figure out how it is fueling and how the tune looks.
Still a canned tune, they didnt do any logs for the tune, so its not the best.
A lot of times with canned tunes they don't factor in elevation ( messes with air density) so they will be a off... a canned tune for the most part is put in place so u can drive the car to a tuner to get dialed in.... if u don't have one u should get a afr gauge before u go to get tuned....
first off do you have a wideband, if not take your car and throw it off a cliff, if you do great job bro. start here, look inside your engine bay for a vacumm leak. If none, go to the maf;/ air filter clean both. check throttle body. Make sure the tune on your car is correct, call tim up at zzp and ask him the same question your asking us. i do not like canned tunes, and i hope you can afford a real tune soon.
good luck
good luck
good luck
good luck
