For the SC guys
Old Oct 12, 2010 | 01:29 PM
SS-Performance-RS's Avatar
For the SC guys
This question is for the SC guys. I met this dude on base today with a SS/SC balt Vic Red with a high rise. He says that when he pulls up to a stop light or stop sign his car starts surging and sometimes shuts off. Diagnosis? Mods are KNN Cold intake and Magnaflo exhaust. Filter hasnt been serviced in 20,000 miles
Ok so we cleaned the filter and it was filthy. Also cleaned the inside of the pipe and it is still doing the same thing. What should we do now? I need a guide on taking off the TB and cleaning it.
Old Oct 12, 2010 | 01:31 PM
CobaltVenomSS's Avatar
its def the TB... take the intake off and the TB has 4 BOLTS i think...take those off amd clean the **** out of it lol
Old Oct 12, 2010 | 01:37 PM
Render2009's Avatar
this.. the throttle bodys on these get nasty as ****.
Old Oct 12, 2010 | 01:39 PM
Staged07SS's Avatar
Administrator
Administrator
Agreed !!
Also, inspect the MAF sensor. It may be dirty.
Old Oct 12, 2010 | 01:40 PM
rnjmur's Avatar
Probably a dirty TB, maybe dirty MAF as well.
As far as removing the TB:
1. Remove the intake tube that goes between the TB and lower intake pipe.
2. Remove 4 bolts from TB and remove.
3. To disconnect the TB harness you remove the plastic locking pin (I used a small jewelers screwdriver to push down on the tab) then push on the connector's release tab and pull the connector off.
4. Use TB cleaner and a rag to clean the TB and butterfly. Be careful when cleaning and moving the butterfly so you don't damage it.
5. Do steps in opposite order to install.
Do not lose or forget to put the plastic locking pin back in place. I also always replaced the TB gasket when cleaning the TB. It is like a $15 part and since you have it all off anyways you may as well replace it.
Lapila82's Avatar
Might not have anything to do with it, but is he tuned for his mods?
Old Oct 12, 2010 | 01:47 PM
He is not tuned for his mods
Old Oct 12, 2010 | 02:19 PM
Billig ss/sc's Avatar
Could also be an EVAP issue. I have a shitty EVAP issue going on right now and mine does the same thing. When he gets gas, does the car surge like that when he first starts it up after filling? If so, it's the EVAP.
Old Oct 12, 2010 | 02:25 PM
rallycobalt06's Avatar
just throwing out another possibility..... clogged cat.
Old Oct 12, 2010 | 02:26 PM
Staged07SS's Avatar
Administrator
Administrator
I had that happen to my car last fall. It was caused by the EVAP purge solenoid.
Old Oct 12, 2010 | 02:36 PM
How much did it cost to fix? Did you do it yourself?
Old Oct 12, 2010 | 02:37 PM
Staged07SS's Avatar
Administrator
Administrator
I fixed it myself.
Buy the part on GMpartsdirect. I think it was $20. Let me check for you.
Old Oct 12, 2010 | 02:40 PM
Awesome!
Old Oct 12, 2010 | 02:41 PM
Staged07SS's Avatar
Administrator
Administrator
Type in part #12597567 on GMpartsdirect
It's $22.13. It's a simple fix man. I kept getting bad gas cap & EVAP codes until i finally tracked down the failing part.
Old Oct 12, 2010 | 02:43 PM
"Fuel Tank Evaporator Control"?
Old Oct 12, 2010 | 02:46 PM
Staged07SS's Avatar
Administrator
Administrator
Yeah, they call it that, but it is actually called the EVAP purge solenoid. It evaps vapors from the fuel tank into the throttle body to be burned off.
http://www.crateenginedepot.com/pdfs...Fuel_Parts.pdf
^ Look up the description of part 915.
Old Oct 12, 2010 | 02:51 PM
Awesome man, thanks!
Old Oct 12, 2010 | 02:54 PM
Staged07SS's Avatar
Administrator
Administrator
No problem !! Let me know how you make out.
Old Oct 13, 2010 | 10:41 AM
Ok so we are gonna take the tb off this weekend and clean it. Will report back the results
dennis69
Oct 20, 2015 04:49 PM
Oct 13, 2015 09:32 PM
justinchinn
Oct 2, 2015 12:18 PM
roth
Sep 26, 2015 12:16 PM
