screws stuck n stripped!!! help!!!
Old Jul 10, 2009 | 04:39 PM
06cobalt_ss's Avatar
Exclamation screws stuck n stripped!!! help!!!
I'm trying to change my plugs n injectors but I ran into a problem. The 4 allen key screws on the top of the motor cover are stripped and the one that wasn't stripped is so tight n stuck I can't get it off. The screws on the injector n fuel rail cover are the same way. What can I do to get these screws off!
Old Jul 10, 2009 | 04:46 PM
SCcobaltSS's Avatar
http://www.monstermarketplace.com/Ge...g2444a380.html
as seen on tv!
Old Jul 10, 2009 | 04:49 PM
ssyellow's Avatar
the grab it!...or something like it might work.
http://www.amazon.com/Alden-8440P-4-...7258840&sr=8-1
aww no **** you had the same idea??? wtf lol
I saw it on Pitchmen
Old Jul 10, 2009 | 04:54 PM
hackeragent061's Avatar
just go to sears they sell tons of screw/bolt out tools
Old Jul 10, 2009 | 08:16 PM
Lol perhaps sumptian that doesn't take 6-8 weeks for delivery. My car is gettin tuned mon need hgelp now
went there got the screw remover and it just mad it worse. the head of the screw is almost gone. what else can i do. any ideas?
Last edited by 06cobalt_ss; Jul 10, 2009 at 08:16 PM. Reason: Automerged Doublepost
Old Jul 10, 2009 | 08:22 PM
Sunburst_SS's Avatar
get a drill and some bits......drill the heads off of em, just be carful not to mess up the stuff underneath
Old Jul 10, 2009 | 08:25 PM
06SS ALL DAY's Avatar
Billy Mays RIP
Old Jul 10, 2009 | 08:28 PM
smthomas556's Avatar
I ran into the same problem. Take a dye grinder with a cutting wheel attachment and grind a valley into it. Then take a flat head screwdriver and place it into the valley and turn. You basically just turned the torx bolt into a flat head bolt. Hope this helps.
Old Jul 10, 2009 | 08:31 PM
SSchargedSS's Avatar
thats some good info there, just be sure tp get rid of any metal shavings/flakes
you got my idea first
Old Jul 10, 2009 | 08:42 PM
Brandon97Z's Avatar
easy out...
Old Jul 10, 2009 | 09:01 PM
golden chicken's Avatar
first of all...it's a T30 torx, NOT an allen. if it's really stuck in there, an impact driver seems to be one of the best tools for loosening them.
you can replace with M6x1.00x20mm shouldered hex head machine screws once you get them out, and then they'll never really be stuck again.
now that it's pretty much destroyed, die grinder/flathead is a good way to try, but i'll also suggest using a can of compressed air upside-down to spray freon on the spark plug cover to try to shrink the aluminum slightly and relieve some of the pressure on the head of the screw.
turbochargedss2012
Sep 20, 2023 12:17 PM
How to Guide
57
Oct 15, 2015 11:56 AM
importkiller
Sep 30, 2015 07:18 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
