self's turbo build
Old Apr 25, 2010 | 10:17 PM
  #76
slowswap's Avatar
Originally Posted by Ryan@zzp
Just curious as to what turbos out perform the 252ext, 256ext in the same category?
FP HTA GT3076r. Hell any HTA FP turbo. I guarantee your next post says well thats xxx much more money, but you pay for what you get.
Old Apr 25, 2010 | 11:41 PM
  #77
Ryan@zzp's Avatar
When you described the turbo's you thought to be better I was going to say show me. That is what my next post was going to be. What does your guarantee come with and what is my next post going to be,lol.
Old Apr 29, 2010 | 09:53 PM
  #78
selfinfliction's Avatar
stopped by the shop today, it's not going to be finished until next week... got it up on the rack and he got some of the stuff done, but he wanted to run the return into the block where it should be, so we're going to do that instead of into the oil pan.
boring pic
here's a cool pic.. this is his wife's car he's rebuilding, outlaw 8.5 class and this thing is prepped properly
here's what it sounds like lol
http://www.youtube.com/watch?v=QLG38jnDvHc
Old May 3, 2010 | 11:48 AM
  #79
FYI the zzp downpipe does not bolt up properly to the hahn catback. shop is making some "adjustments"
not sure exactly what it was, he's fixing it now though... should know tomorrow
Old May 4, 2010 | 09:28 PM
  #80
it idles and revs smooth as could hope for and the hahn exhaust went from sounding like complete **** to earlobe sex
http://www.youtube.com/watch?v=_Cv4nbZft60
Old May 20, 2010 | 09:37 PM
  #81
http://www.youtube.com/watch?v=pcYKR2f4zVA
put out about 320whp/330wtq @ 22psi
didn't run it out but to 6500rpm, no reason to rev it out any higher. the a/f dropped off about 5500, and that was evident on the torque curve, so i'm gonna send the logs off and get it leaned out a wee bit and see what she can do
Old May 21, 2010 | 12:51 AM
  #82
hungryhip-ccp's Avatar
very decent for mustang numbers, and the circumstances.. i would assume you will pull quite a bit more out of it with the maf spot on.
that turbo @ that boost level is good for a easy 350-360 on a conservative tune on a mustang dyno which is getting close to 400 on a dynojet.
what was your afr, idc and your timing up top?
Old May 21, 2010 | 05:15 AM
  #83
it bottomed out at 11.6 afr, idc was 80%... think it popped 81% for a split second and timing was 16 across the board, then hit 17 for about the last 200ish rpm and iat2's were right at 100 degrees at the end in 75 degree ambient temps
i did like the hp curve on it, it was pretty flat all the way out from spool. hopefully if i can ever get in touch with area he can do some tweaks on it... haven't seen him around for a while now
Old May 21, 2010 | 09:58 PM
  #84
one last q
what was the lbs/min? about 32-34? that 80% idc matches with your numbers and your afr perfectly.
when you see 38-40lbs/min and 100-110 idc on the 60's your right @ 400whp
none the less thats a perfect street car i think, anymore and traction is a major issue! right now that motor is probably fat and happy too. the tvs would of never pulled out those numbers withough hrs and hrs of tuning and RG
Old May 21, 2010 | 11:33 PM
  #85
yeah i'm talking with byt right now, he said he can see some compressor surge on the logs, i really don't have any idea where to start on it cause i can't hear it inside the car on the street and the boost gauge doesn't flutter. but you can hear it on the dyno run and he said he seen it on the logs without even watching the vid.
dunno if i need to just go ahead and yank the LIM and install a saab, or if by some strange way the turbo wasn't pulling enough air from inside the fender cause there was no fan on it.. just one on the fmic. the BOV was cranked all the way down, so i did loosen it up. bad thing is the turbo has an internal wastegate so not sure if maybe it is causing it either.
Old May 30, 2010 | 02:30 AM
  #86
stenguyen1's Avatar
awesome build man. haven't really read everything but seems like everything is falling right into place.
Old Jun 9, 2010 | 08:58 PM
  #87
got the lsd trans and act clutch being put in as we speak, should be finished on friday... no one had any trans fluid so i had to buy some near $20/quart royal purple lol
also doing some changes on the system, someone is working on an intake similar to the 2.2/2.4 which will be better than modifying my setup for a log style intake. waiting on that to be finished,
and also up in the air between getting a custom cast turbine housing that has an external wastegate provision or having a segregated turbo elbow with a 2.25" and 1.5" pipe coming off the turbo and into the exhaust. right now the cast elbow chokes down to a point just a bit bigger than 1" and i think that may be causing the boost fluctuation issues... you can only put so much air through a little hole
Old Jun 15, 2010 | 06:05 PM
  #88
installing act clutch kit and the tolerances are extremely tight. called up their tech support with measurements of all the stuff and they are supposed to be getting back to me.
has anyone else installed one of these kits, and if so did you have problems with the install?
Old Jun 15, 2010 | 08:25 PM
  #89
cobaltguy889's Avatar
i have that same exact SC delete kit from ATP. I love it.
Old Jun 15, 2010 | 08:32 PM
  #90
terry11's Avatar
What tolerances are you talking about
Old Jun 15, 2010 | 08:49 PM
  #91
06blackg85ss's Avatar
that seems a bit low for a 3071r but not bad, going to be a fun as hell car
and on afr's I usually shoot for 11.4 on pump gas for a little safety. 16-17 degrees of timing on pump gas is nice and conservative too, I've been able to get away with as high as 20 on 22psi on pump gas (bigger turbos) and usually get away with it on 93 octane
Old Jun 15, 2010 | 08:57 PM
  #92
rico's Avatar
man i Want to already change my turbo i have a chance to get ur old turbo paul the 60-1 but idk lol
Old Jun 15, 2010 | 11:00 PM
  #93
bolt holes on the flywheel
yeah we've figured out 2 things. i gotta get this stock cooling system off, and the cast garrett turbo elbow chokes down one point about 1.5", it was designed for the 2.2 and lower boost, not 20psi 300whp+ lol
once the clutch and trans is back on, i'll be getting a divorced elbow with separate pipe for the wastegate and exhaust and then run both of them back into the downpipe
Last edited by selfinfliction; Jun 15, 2010 at 11:00 PM. Reason: Automerged Doublepost
Old Jun 16, 2010 | 05:57 AM
  #94
there ya go. I don't like the stock intake mani, it was choking me setup down for a while, as for that cast elbow, that's terrible lol. That would help explain it
and rico, you should get it, kinda laggy below 4k rpm, but god up top that thing is a monster
Old Jun 16, 2010 | 07:39 AM
  #95
just got back in the office and ACT left a message, they've already shipped me a new flywheel. he said the measurements were just a bit off and would work, but they'd like to get the unit back because they don't like any questionable parts floating around.
ACT follows through with great service as always.
Old Jun 16, 2010 | 08:23 AM
  #96
tim0shel's Avatar
^ good to hear thats good customer service right there and you know they care about quality.
awesome build just sucks cause im so confused on parts etc. if i ever decided to go turbo.
Someone needs to make a full optional parts list and were to buy for a complete sc to tc setup lol.
Old Jun 16, 2010 | 08:34 AM
  #97
There already is quite a few, just search
Old Jun 16, 2010 | 09:31 AM
  #98
terry11's Avatar
Let's see some of this in my tune
Old Jun 17, 2010 | 06:15 AM
  #99
tim0shel's Avatar
Oh im sure there is i hadnt done the search yet i guess because im not to that point yet for the whole swap. Guess i will find all that i need when i reach that point. Thanks,
Old Jun 17, 2010 | 06:51 AM
  #100
search for infe's posts he did an entire build thread with pretty much everything listed.
I deleted mine
