Shit!
Take a clothes hanger.On one end make a loop with about a 2 inch tail coming back to you.It will look like a V with a circle under it. Slip it in the side of the door window and hood the unlock knob in the V and pull upwards towards you.The loop sorta acts like a spring and gives it some tension and it want slide out.
..Worked for me first try..
sounds like that guy from the story here in florida where some dudes brother wrecked his srt in a street race, so he kidnapped the kid he hit and got thrown in jail...
they bring a locksmith out to unlock your door with a plastic tool. Free, just sign the paper.
ive done this before.. . i used two screw drivers and started from the top corner of the door (passenger side, top left) and got one screw driver in, pulled, put the other in a little farther up, pulled.. then once you get the the middle of the door, use a straight clothes hanger to push the door unlock button... it works, might scratch a little, took me about 10 min to do, first time...
i did that once when i was younger. went to the bar, had MANY drinks, just to come out and find that the car was running with all the doors locked! i obviously couldn't call the cops or anyone else to help, so we put a rock through the rear window and opened it up that way. wasn't the smartest plan, but it worked!
the locksmiths have plastic ones that just scuff
epic
yea your going to scratch the inside of your door a little bit, but you know your doin it right if you can only see it mostly when u open the door...trust me i know that way works, i have personally done it.
