Is the shorter belt available from GM yet?
Old Jul 10, 2006 | 11:23 AM
OBSSSD's Avatar
I'm about to order a 2.7" from Billet flow and would rather not change the idler pulley
Old Jul 10, 2006 | 11:28 AM
GSoccer24's Avatar
Yes, Search!
Old Jul 10, 2006 | 11:35 AM
06blackg85ss's Avatar
PN# 12597993 OR something like that (off the top of my head) just got mine in..
Old Jul 10, 2006 | 11:38 AM
budman128's Avatar
yeah Ive had mine for a couple of weeks cant remeber the part # use search
Old Jul 10, 2006 | 05:18 PM
OBSSSD's Avatar
I did search and I know the part# is 12597993. It's just that everyone keeps saying that they are on indefinite back order. I called my local dealer and they say they can get them, so I guess I will try and special order it.
Can I run the 2.7" from Billetflow without changing the idler pulley if I run the shorter belt?
Chris
Old Jul 10, 2006 | 05:23 PM
get an adjustable tensioner... trust me your belt will stretch from the heat from the blower snout and you'll get crazy high rpm slippage.... I just got mine in from gm parts direct... took about three weeks though.
Old Jul 10, 2006 | 06:17 PM
OBSSSD's Avatar
Talked to Doug at Billetflow and it looks like I am going to try the 2.7" with the shorter belt and 76mm idler pulley. He is sending me the 70mm and the 76mm in case the 76mm is too big. I'll keep everyone posted!
Chris
Old Jul 10, 2006 | 06:41 PM
fljohnboy's Avatar
Adjustable tensioner from where and how much?
Old Jul 10, 2006 | 07:17 PM
CrateEngineDepot's Avatar
Here is a link to the belt:http://www.crateenginedepot.com/stor...P1592C144.aspx
Old Jul 10, 2006 | 08:20 PM
zzp sells em for 99.... it works good.. trust me
Old Jul 10, 2006 | 08:30 PM
silverSS's Avatar
go with the belt...
Old Jul 10, 2006 | 11:19 PM
OBSSSD's Avatar
I am definately getting the belt if it is available, however, it is for a 3" pulley so I am just trying to figure out which idler to go with - the 70mm or the 76mm?? Doug said that if you only did the idler pulley you would need more than you have room to go like 86mm - so he said use the shorter belt and the new idler to ensure little to no slippage
DarrenGC
Dec 24, 2021 01:55 PM
justinchinn
Oct 2, 2015 12:18 PM
cw383
Sep 30, 2015 12:41 AM
grampss
Sep 27, 2015 08:51 PM
bobbob160
Sep 15, 2015 11:31 PM
