some CEL codes
Old Feb 27, 2010 | 06:32 PM
Killa702's Avatar
some CEL codes
p0420-catalyt efficiency low-bank 1
p0452-fuel tank pressure sensor condition
p0463-fuel level sending unit condition
p0171-fuel trim bank one condition
p2228-barometric pressure (BARO) sensor curcuit low voltage
i have all these codes popping up?
i recently changed the fuel pump cause of the GM recall.
my performance is fine except im wasting more gas than usual and my car vibrates sometimes when im at high speeds
what could it be? cause it cant be all those things at once i dont think..
Old Feb 27, 2010 | 06:51 PM
sundevil07's Avatar
take it back to the dealer
Old Apr 4, 2010 | 12:23 AM
Killa702's Avatar
will they find the problem for free ? cuz i have no warranty
Old Apr 5, 2010 | 12:41 PM
StageII07's Avatar
No they wont once ur warrenty is up your pretty much SOL.. unless its the recall ****..
Old Apr 5, 2010 | 12:47 PM
kevinj4891's Avatar
your 0420 code is for exhaust...its not bank 1, its for the second O2 sensor after the cat...usually comes on with modified exhaust... it means that your emissions aren't as clean as it should be. get a non-fouler or "L" spacer and you'll get rid of it.
other than that,, i dont know
Old Apr 5, 2010 | 07:32 PM
Dainslaif's Avatar
Sounds like fuel pump.
Old Apr 5, 2010 | 07:42 PM
Dirty25RS's Avatar
I see a story....
something is wrong with the fuel system. dont know what the root cause is
but the fuel trim code + you saying gas mileage sucks sounds like its running rich. take a spark plug out and if its black and goo-ie this confirms richness.
cars that run rich dont burn all their fuel by definition. so it goes on out the exhaust and coats the catalytic converter with a nasty mixture of unspent hydrocarbons and carbon (just like the spark plug). At best...thats it. and thats why ur throwing the cat code.
At worst...you had a slight misfire at some point (possibly from the richness) that ignited the unspent hydrocarbons on the cat and blew it to smithereens (spelling?)
I've seen it before.....
also when a sensor circuit is "too low" 50% of the time that means the sensor is dead. MAF cars dont really use baro pressure for any tuning decisions tho. just emissions systems like EGR, PCV, and Evap canister controls
now that i type it out and think about it I think i get it.....I think the new guy put ur pump in and fucked up the whole in-tank assembly whilst doing it.
Old Apr 5, 2010 | 08:00 PM
sundevil07's Avatar
why I said take it back to the dealer ^
Old Apr 6, 2010 | 12:46 PM
insylem's Avatar
Vibration at high speeds typically are caused by a tire being out of balance.
Also correct me if I'm wrong, but isn't P0171 the LEAN code and not the Rich one?
Old Apr 6, 2010 | 04:43 PM
Dainslaif's Avatar
Yes. Yes it is. Pump isn't working right, it's starving the car.
Old Apr 6, 2010 | 04:55 PM
crypticscifer's Avatar
Agreed. But what about the gas mileage.
Old Apr 6, 2010 | 05:09 PM
Dainslaif's Avatar
Well, the fuel pump install was messed up, so it could be anything at this point. Fix the big problem first and see if the mileage was just a side effect of that.
Old Apr 6, 2010 | 08:13 PM
true
Old Apr 8, 2010 | 07:45 PM
Killa702's Avatar
thx for all the adises guys im goin to take it back to the dealer asap
turbochargedss2012
Sep 20, 2023 12:17 PM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
