Spark Plugs
Old Feb 3, 2012 | 02:56 PM
Bergeron85's Avatar
Spark Plugs
Going to replace the spark plugs in my Cobalt this weekend. Any suggestions? Its A completely stock SS/SC with Borla high flow CAT and muffler.
Old Feb 3, 2012 | 03:04 PM
time and time again i keep hearing ngk brk-07e or something like that. google search something like 'best spark plugs cobaltss.net' or something i'm sure ull find a good thread on here about them. also, i might have a set if ur interested, only used them for 5k miles
Old Feb 3, 2012 | 03:16 PM
Whitnith's Avatar
BKR7E are one step colder, which you don't want if you're stock.
Stock plugs are BKR6E if you want to go NGK. I know they aren't gapped correctly for stock, but I couldn't tell you what they should be gapped to.
Old Feb 7, 2012 | 01:30 PM
Bergeron85's Avatar
Got some Autolight double platinum and gapped them .042. Still has a bit of a surging issue. Will do the fuel filter next.
Old Feb 7, 2012 | 01:33 PM
Staged07SS's Avatar
Administrator
Administrator
The surging is most likely due to spark blow out.
0.042" is too large of a gap for the LSJ.
Gap them to 0.035" if you are stock or lightly modified.
Autolights have been known to give people trouble with these cars.
http://www.crateenginedepot.com/stor...P2630C193.aspx
^ These are what you should have purchased.
Old Feb 13, 2012 | 11:29 AM
Bergeron85's Avatar
Really? I got the gap number from the Haynes book. Really think that the gap should be smaller?
Old Feb 13, 2012 | 12:20 PM
08SStc's Avatar
for a FI motor, yes, a .035 gap is much more appropriate. that .042gap sounds like maybe the 2.2 or 2.4l motors
Old Feb 13, 2012 | 12:27 PM
Staged07SS's Avatar
Administrator
Administrator
The Haynes book along with the actual owners manual provide the wrong gap for the LSJ.
My car's plugs came gapped from the factory at 0.035" (my owners manual claims 0.039" for 07's).
Old Feb 13, 2012 | 02:58 PM
Bergeron85's Avatar
Really? Oh wow, that stinks. I will take them out and re-gap them. Hopefully it will run a lot smoother. Thanks
Old Feb 14, 2012 | 07:13 AM
Staged07SS's Avatar
Administrator
Administrator
It should run a lot better.
Let me know.
Old Feb 14, 2012 | 08:11 AM
Bergeron85's Avatar
Let me know.
Okay, Probably wont get to it till this weekend. Will update though.
Old Feb 14, 2012 | 08:57 AM
CobaltSS 16's Avatar
Any suggestions for my LSJ? It's tuned with a 2.8 and 60s. I got stock plugs right now and it runs pretty smooth but I need to change them out anyways since they're getting old.
Stay with the stock ones?
Old Feb 14, 2012 | 09:46 AM
Pepsi's Avatar
Ngk 2 step cooler
Old Feb 14, 2012 | 09:50 AM
Staged07SS's Avatar
Administrator
Administrator
Originally Posted by Pepsi
Ngk 2 step cooler
No.
For his mods 1-step colder plugs are more than enough.
Old Feb 16, 2012 | 10:19 AM
user 72239's Avatar
When I had my LSJ I bought Autolite's Iridium's, gapped to .032 and never had issues.
I was getting random missfires in my LNF, bought Autolite' plugs and gapped to .032 Missfire gone.
just my .02
Old Mar 24, 2013 | 12:31 PM
BallinBlackbaltSS's Avatar
I have an 2006 Cobalt ss sc with CAI stage two i need to replace my plugs and i was looking at the NGK but, was not sure what i needed if i needed 1 colder or 2 colder or what any help would be appreciated thankS! Thats also Just GM stage 2
Old Mar 24, 2013 | 01:31 PM
Whitnith's Avatar
1 step colder will be fine, the BKR7E.
Old Mar 24, 2013 | 02:02 PM
Thanks!
Old Mar 25, 2013 | 07:22 AM
Staged07SS's Avatar
Administrator
Administrator
Stock heat range.... stock replacement plug for GMS2.
Gap them at 0.035".
Old Mar 25, 2013 | 10:28 AM
Vander Nars's Avatar
I ran 1 step colder on stage 2, wish we had a better guide on when what plug is needed at what stage.
Old Mar 25, 2013 | 10:31 AM
SS89's Avatar
I replaced mine last week and used NGK BKR7E on my stock LSJ, I had bought them for when I'm going to install my 2.9" pulley but installed them regardless.
Old Mar 25, 2013 | 10:38 AM
Staged07SS's Avatar
Administrator
Administrator
GMS2 was designed with the stock plugs thus why I always recommend them to members asking which plug to get.
I ran the stock plugs through GMR S3, and just recently dropped down to the BKR7E's once I installed my cams.
You can technically run 1-step colder plugs with GMS2, but "can" fall into issues with fouling due to not producing the power / heat to warrant a colder heat range.
You had the GMS2 hardware (pulley, injectors, etc.) but were running a custom tune werent you? Prob making a bit more power than what GM's tune provides.
Old Mar 25, 2013 | 12:02 PM
Yeah i had custom tune, im still running 1 step on a 2.7 now just working on some issues
Old May 9, 2019 | 10:54 AM
Linkinpark21585's Avatar
Spark plugs?
I see the stock spark plugs if chosen as NGK are the BKR6E with a heat range of 6 and 1 step colder are the BKR7E with heat range of 7 and 2 steps colder are the BKR8E with heat range of 8. And rule of thumb for every 75 to 100 HP drop 1 step colder when doin internal engine work such as cams and so forth. But what about the iridiums. The BKR7EIX or the BKR8EIX? I have a zzp 2.7 pulley, cold air intake, zzp headers with full exhaust,zzp dual bypass, and zzp larger heat exchanger (radiator). Any suggestions?
Rocker09Ss
Oct 6, 2019 04:21 PM
09black$$
Jun 1, 2010 08:34 PM
_UnLiMiTeD_
Jun 11, 2009 09:11 AM
WhiteSSBalt
Apr 10, 2008 06:50 PM
Xenozx
Feb 11, 2006 08:36 PM
