ss/sc 300hp
Old Apr 19, 2009 | 05:10 PM
  #76
1badBlueberrySC's Avatar
ha ha ha ha
  #77
ha ha ha ha
Old Apr 19, 2009 | 09:22 PM
  #78
StevesBlack06's Avatar
ill be over 300 if not closer to 350 at the wheels if i can find a good tune for sure... ive seen a redline with 400+ on the m62. mods are in vbgarage
Old Apr 19, 2009 | 11:09 PM
  #79
BoostedYards86's Avatar
i dont see 400whp on the stock m62...
Old Apr 19, 2009 | 11:11 PM
  #80
rico's Avatar
300-320 yes. 400hp on the m62 whoa idk about all that lol
Old Apr 19, 2009 | 11:15 PM
  #81
heck with 10:1 cr and a good set of cams with a good port job on the head i can see maybe 340 with a very small pulley. but thats about it.
Old Apr 19, 2009 | 11:52 PM
  #82
hatrickstu's Avatar
i believe a well tuned meth, 2.7, ported head car could MAYBE get it.
Old Apr 20, 2009 | 12:16 AM
  #83
i was thinking a 2.6...with a ported head the heat wouldn't be that bad. only about 13psi peak boost. would be pretty efficient.
Old Apr 20, 2009 | 12:22 AM
  #84
hatrickstu's Avatar
yea im not sure on how much the boost would drop, could be right
Old Apr 20, 2009 | 01:10 AM
  #85
haha just ask the man he answers just about every question lol.
Old Apr 20, 2009 | 01:11 AM
  #86
hatrickstu's Avatar
im actually working some math to decide on my final m62 setup right now.
Old Apr 20, 2009 | 11:10 AM
  #87
riceaters redline was over 400whp on the m62. their are posts about it floatin around somewhere...
Old Apr 20, 2009 | 11:39 AM
  #88
i was unaware of that. I only talked to him a few times, but I had no idea he was able to pull out that much.
Old Apr 20, 2009 | 11:42 AM
  #89
OneCOLDBIZL272's Avatar
Originally Posted by startingline05
anyone one know of any lsj's with eaton blowers pushing 300hp?
im pushing over 300 on stock m62 blower.
Old Apr 20, 2009 | 11:46 AM
  #90
mods??
Old Apr 20, 2009 | 11:49 AM
  #91
freakta's Avatar
it can be done easily, but not with boltons alone, im sure someona has with just boltons but port the head get some cams and cam gears, make an intake manifold and run the hell out of the engine to 8200rpms youll get there, i was going to but a turbo fell in my lap and it just is easier
Old Apr 20, 2009 | 11:51 AM
  #92
elecblue06's Avatar
with cams, PNP head meth 2.7 pulley dual pass enplate or opt b .. full bolt ons as well also maybe a slight bump an CR to finish it off and you'll be there
oops what he said lol you got to it before me lol
Last edited by elecblue06; Apr 20, 2009 at 11:51 AM. Reason: Automerged Doublepost
Old Apr 20, 2009 | 11:55 AM
  #93
this is everything that i have that pertains to the motor and suspension, i have more done to the car than this but everything is is cosmetic
Crank Platinum Coated,Cross-Drilled,Knife-Edged,Lightened,Balanced /10.5:1 Pistons / Balance Shaft Delete Kit / New Sleeves / Crank Rod Bearings / Port&Polish Head / ARP Head Studs,New Main Studs
ported intake manifold
Ported Supercharger
Hardened Oil Pump Gears
Custom 3” Intake
Walbro 255LPH Fuel Pump
Oil Catch Can
GM4.2L Throttle Body
Fuel Filter
Dual Pass Intercooler End Plate
60LB Injectors/ Injector Harness 2 Step Cooler Spark Plugs
2.7 Polished Pulley
Stage 2 Hub $ Bolts
Water / Methanol Injection Kit
NS II Performance Tires
Trans Mount Bushings
Supercharger Coupler
Adjustable Tensioner
Tenzo-R Lowering Springs
Custom Under Axle 3” Exhaust System With Magnaflow Muffler
Heat Exchanger 30x8x2.5
Stage 2 Axles
Polyurethane Control Arm Bushings
Cometic LSJ MLS Head Gasket/GM Stage 2 Belt
Supercharger Oil/Supercharger Bearings Grease
Spec Stage 3+ Clutch/Aluminum Flywheel
JBP Vortext Long Tube Shorty Header
AEM Wideband
Auto Meter Cobalt Gauges Boost/Oil Pressure/Water Temp
Custom Polyurethane Solid Driver Motor Mount
Custom Tune
Upper Billet Engine Mount
Rear Sway Bar
Parts / Hardware / Fittings
Old Apr 20, 2009 | 11:59 AM
  #94
thats some big money there. Props to you man, awesome mod list.
Old Apr 20, 2009 | 12:07 PM
  #95
thanks... yeah you could say that. i saved on labor did most of work with a friend except for machine work. and that i got a great deal almost labor free.
Old Apr 20, 2009 | 01:21 PM
  #96
coopn8r's Avatar
Why such a high Compression Ratio.. Just curious..
Old Apr 20, 2009 | 01:26 PM
  #97
elecblue06's Avatar
i think a better question is ... why not if you're building your engine why not go big or go home
Old Apr 20, 2009 | 01:34 PM
  #98
its only a full point from 9.5:1 stock....they always say go big or go home.
Old Apr 20, 2009 | 01:43 PM
  #99
startingline05's Avatar
So how much are u pushing with that set up
Old Apr 20, 2009 | 01:45 PM
  #100
-Jayson-'s Avatar
Ported Supercharger
Custom 3” Intake
Oil Catch Can
Fuel Filter
2.7 Polished Pulley
Stage 2 Hub $ Bolts
Stage 2 Axles
AEM Wideband
Custom Tune
Rear Sway Bar
NICE! Jelous
Im loving the 10.5:1 compression, how hard was that to tune? the Torque has to be ungodly on that setup.
