stage 2 swap
stage 2 swap
alrite quick question. i searched and found a few threads but none answered my question. i have a 07 with a gm stage 2. i want to swap my stage 2 into a friends 07. will be swaping all parts first. now once pcms are swaped what has to be done. i read somewhere that u just need to turn your key on for 10 mins and do that 3 times and it will be fine. any response that isnt trash will be useful. thankyou
I believe you need to have your vin flashed onto the PCM but I am not sure if it will work with out the vin, and sometimes if you switch PCM's you can get a crank case relearn code. You then need to go to the dealer and get a crank case relearn.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
ThoR294
Oct 4, 2015 08:44 PM
