starts camming at idle
Old May 1, 2013 | 05:19 PM
This? At job wanna try to fix when im off
Old May 1, 2013 | 05:27 PM
night_throne's Avatar
the heater circuit in the headers o2 sensor is going bad or the maf needs to be cleaned or is going bad or possibly dirty throttle body ive seen all 3 of those cause it
Old May 1, 2013 | 05:33 PM
Like its.ok then starts loping worse and worse until it pretty much dies? And i can feed it gas and its ok again
New throttle body few thousand miles ago recently cleaned the maf
No.codes yet
Old May 1, 2013 | 05:43 PM
JapEatr's Avatar
South Central *********
Vac leak
Old May 1, 2013 | 05:58 PM
Sox-Fan's Avatar
Got Brakes?
Didn't you just replace some vacuum lines Adam?
Old May 1, 2013 | 06:21 PM
Hockeyman's Avatar
you have cams and don't know it
Old May 1, 2013 | 06:27 PM
I did. I replaced he little one on top of the sc to that little valve thing on top and the one from that to the (purge valve?) on the drivers side of the engine. Can someone take pics of those so i can be sure i didnt mess up the order?
Old May 1, 2013 | 07:04 PM
Gonna take pics of how i got it in a few..
Old May 1, 2013 | 07:33 PM
Bad-A-SS's Avatar
Check the tb sensor the one on the underside. If it comes out it will sound cammed
Old May 1, 2013 | 07:45 PM
On top of sc
That box on drivers side top of block
Old May 1, 2013 | 08:14 PM
I need to know if that little line in the first pic goes to the top or bottom nipple and same for on that box
Old May 2, 2013 | 08:53 AM
Gelladuga69's Avatar
This was my problem with a cammed idle. Set a code tho.
Old May 2, 2013 | 09:01 AM
well i replaced the lines with fuel lines and used clamps, its in the right order i figured it out. all is well now
Sl0wbaltSS
Nov 21, 2018 11:11 PM
dennis69
Oct 20, 2015 04:49 PM
tomj77
Oct 4, 2015 11:39 AM
jimbofug007
Oct 2, 2015 12:06 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
