Stock Supercharger ported
Old Dec 11, 2014 | 11:43 PM
  #51
armcclure's Avatar
The inlet was not modified. At all.
Old Dec 11, 2014 | 11:45 PM
  #52
Bluelightning's Avatar
Got Bewst?
Originally Posted by Spawne32
I think the point he was making that there is no way to conclusively prove that modifying the outlet improves power when you modify the inlet for a larger throttle body at the same time.
That's fair. A little ridiculous if you think the a stock TB is going to drastically change results but fair if you want to get technical.
Old Dec 11, 2014 | 11:50 PM
  #53
Spawne32's Avatar
Well 9 times out of 10 the performance gains from porting a supercharger are always on the inlet side. Smoothing the inlet port helps by increasing velocity into the supercharger. I'm sure zoomer has details on the testing they did to come to the conclusion he posted. Gains were probably minimal at best.
Old Dec 11, 2014 | 11:55 PM
  #54
Got Bewst?
The low graph is my original blower with a 2.6
Inlet opened for ls4 but not polished.
High graph is a blower with this outlet port only, spacer used for ls4 (less than ideal). Same 2.6 pulley.
So is this incorrect info? Or you just mean the blower you modded the outlet on had a stock inlet?
Interesting theory. But they said the inlet port was never smoothed. Just the inlet opened up on blower 1 to match the LS4 and blower 2 was bone stock. Sub'd for outlet only modification with stock TB dyno testing haha
Old Dec 12, 2014 | 12:21 AM
  #55
armcclure's Avatar
this. The winning blower in the dyno sheet was outlet port ONLY. Zzp tb spacer/adapter to an ls4. The other blower was stock other than being machines out for the ls4 as opposed to a spacer, with the cleanup extending an inch or two into the case.
Old Dec 14, 2014 | 10:21 PM
  #56
Stumpalump's Avatar
My LS throttle body, adapter plate and blower inlet did not match up well. I hogged out the plate and blower snout and the results were dramatic.
Supercharged06SS
Dec 11, 2022 04:47 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
Stuff
Oct 1, 2015 05:47 PM
