Strange Hesistation when Fuel Tank Below Half Full on LSJ
Hi guys,
I installed a 2.8" pulley kit, with FMHE to support the heat, my mods are in my sig.
However, before I installed the kit, I noticed one time when I went to redline (stock LSJ setup) that the car hesitated around 6K RPM. This only happened once before I installed my 2.8" kit.
Now, after installing the kit I immediately noticed the same hesitation as before but now it was occuring MUCH more frequently and I noticed it occured ONLY when the fuel tank is below half full...
I immediately changed my spark plugs and re-did the fuel filter, this didn't seem to affect my problem as when the car drops below half a tank of fuel, it hesistates!
What possibly could be causing this? Keep in mind the car pulls like a freight train with a full tank, it's only when the car gets to half a tank or so that it has hesistation issues above 4K.
THANKS!!
THANKS!!
Is this science, I'm not certain. However, this would signify that I need a new fuel pump I assume. If that's the case I'm pretty surprised as the car only has 77,000 KM on it.
Thoughts?
