stroker lsj build
Old Jan 15, 2013 | 10:53 PM
  #301
SlowBalt_06's Avatar
***** slow and weak!
Old Jan 16, 2013 | 12:13 AM
  #302
mrbelvedere's Avatar
Originally Posted by Tjolley
if u have a hard on for more than 4 hours keep ******...lol
lmao
GDS
Old Jan 16, 2013 | 12:18 AM
  #303
YelCal7's Avatar
Then MrB **** will be SWOLLEN!
Old Jan 16, 2013 | 12:44 AM
  #304
armcclure's Avatar
yep still dose it...but dosnt show any KR
The I'm leaning to something electrical. Idl what exactly. But if it was either spark blowout or fuel issues it wouldn't have done it at the same rpm. Only the same airflow
Old Jan 16, 2013 | 06:54 AM
  #305
Tjolley's Avatar
lmao
Old Jan 16, 2013 | 06:56 AM
  #306
Tjolley's Avatar
im gona put a smaller gap on the plugs and see...
the only thing i have changed is i went from a bkr9 to a bkr6
Old Jan 16, 2013 | 08:27 AM
  #307
c130aviator's Avatar
try BK7RE aka 4644. I gapped mine at .032 never had an issue
Old Jan 16, 2013 | 08:36 AM
  #308
Tjolley's Avatar
i might...im gona yank my injectors out and see how they look.. im gona pull the fuel filter and see wat it looks like
Old Jan 16, 2013 | 06:44 PM
  #309
armcclure's Avatar
Is it pulling lean when it happens?
Old Jan 16, 2013 | 07:01 PM
  #310
Tjolley's Avatar
Not 100% sure my afr goes crazy.
I would say it does.
But my idc goes to like 115% lol
Old Jan 16, 2013 | 07:04 PM
  #311
armcclure's Avatar
You tune yourself?
Old Jan 16, 2013 | 07:12 PM
  #312
Tjolley's Avatar
Majority yes..
Had help from this forum and hpt.
Old Jan 16, 2013 | 07:22 PM
  #313
armcclure's Avatar
If you can't figure anything out, turn off everything electrical and reflash your current tune with a write entire. I've had a car glitch up on me before. Caused insane fuel issues.
Old Jan 16, 2013 | 07:31 PM
  #314
Tjolley's Avatar
Hmm i havent thought about that..ill try it on my way home
Old Jan 16, 2013 | 07:35 PM
  #315
armcclure's Avatar
Make sure there is NOTHING that can cause electrical interference. Scanner, radio, lights, gauges, etc.
If a flash fails you just try again. If a write-entire fails you can lose the PCM.
Old Jan 16, 2013 | 07:37 PM
  #316
Tjolley's Avatar
Hmm good to know.
Old Jan 16, 2013 | 07:53 PM
  #317
InfraRedline's Avatar
Make sure you have a good battery as well since a write entire takes about 5 minutes.
Old Jan 16, 2013 | 08:11 PM
  #318
Tjolley's Avatar
Its about a month old.
Old Jan 16, 2013 | 08:17 PM
  #319
armcclure's Avatar
Meant computer battery
Old Jan 16, 2013 | 08:19 PM
  #320
I meant both really. Ive seen both die lol creates a mess!
Old Jan 16, 2013 | 08:45 PM
  #321
***** slow
Old Jan 16, 2013 | 09:16 PM
  #322
Tjolley's Avatar
Originally Posted by SlowBalt_06
***** slow
it will smoke that Prius..lol
Old Jan 19, 2013 | 09:02 PM
  #323
My writes take 50 seconds. ?
Old Jan 19, 2013 | 09:09 PM
  #324
Write calibrations only takes about 35-45 seconds, while a write entire takes a few minutes.
Old Jan 19, 2013 | 09:10 PM
  #325
BLAZIN07SS's Avatar
I'm too JDM for you
That's for a write calibration only, not a write entire
