stroker lsj build
Old Jan 23, 2013 | 10:27 PM
  #351
c130aviator's Avatar
I am running my stock cams as well right now, due to money, but I want stage 2 cams or something that will allow me to rev out to 7500-8000. when i do cams I am also doing the ATI balancer. That is all I have left to do for revving.
Old Jan 23, 2013 | 10:34 PM
  #352
Tennpenn83's Avatar
I will have some ZZP STG2 cams for sale here shortly...
Old Jan 23, 2013 | 10:38 PM
  #353
i want first dibs at this, i have income tax money coming. Please let me know first. Please.
Old Jan 23, 2013 | 10:57 PM
  #354
Tjolley's Avatar
Im getting customs...oh ya..
Old Jan 23, 2013 | 11:07 PM
  #355
I can get customs for 500 bucks. mrbelvedere let me in on a very cool find of his. But yeah custom is best. I want turbo cams btw Tennpenn, are those SC cams?
Old Jan 23, 2013 | 11:20 PM
  #356
InfraRedline's Avatar
He has Stage 2 BLOWER cams. You do not want.
Old Jan 23, 2013 | 11:23 PM
  #357
k, thanks. sorry to get your stuff so far off topic, Tjolley.
Old Jan 24, 2013 | 06:24 AM
  #358
Tjolley's Avatar
Its all good
Old Jan 24, 2013 | 07:20 AM
  #359
Tjolley's Avatar
Just ordered the clevite rod bearings and need arp 2000 rod bolts.
Today will be the longest 12 hour shift. Cuz my custom made pistons are showing up. Woot.
7 & 1/2 weeks later
Old Jan 25, 2013 | 02:28 PM
  #360
Tjolley's Avatar
Ordered new fuel pump today..
Ok i go home yesterday expecting to see my pistons..no ****** pistons.
So i wait till today call wiseco today. I get a tracking number it says it was delivered yesterday left on the porch.
I call wiseco back they tell me they sent them to 2721 i said it was 2761. I double checked me order form and all that. I filled it out correct..
So i have my wife go down to the address and no one is home...im so ****** pissed
Old Jan 25, 2013 | 05:55 PM
  #361
Melon's Avatar
That sux big time!
Old Jan 25, 2013 | 07:09 PM
  #362
Tjolley's Avatar
im happy now
Old Jan 25, 2013 | 08:33 PM
  #363
armcclure's Avatar
Holy compression mustache
Old Jan 25, 2013 | 09:13 PM
  #364
Tjolley's Avatar
12.1:1
Old Jan 26, 2013 | 07:33 AM
  #365
Tjolley's Avatar
eagle 2.2 rods.
Long rod lsj anyone lol
here's a sneak peek
Old Jan 26, 2013 | 09:01 AM
  #366
574's Avatar
574
Excuse me while I clean up my keyboard... thanks..
Old Jan 26, 2013 | 09:08 AM
  #367
Tjolley's Avatar
Lol thanks...i did the same...i had a hard on all day yesterday...
They r the center pice on my kitchen table
  #368
574's Avatar
574
Dat exhaust port... DAMN that gets me excited haha
Old Jan 26, 2013 | 09:13 AM
  #369
Tjolley's Avatar
Any one want to see the inside of an LSD
Well here you go.
Old Jan 26, 2013 | 10:39 AM
  #370
Tjolley's Avatar
Think i might be able to make this lsd lock up tighter. Might put more stress on the cv's but oh well..lol
Old Jan 26, 2013 | 10:44 AM
  #371
SlowBalt_06's Avatar
sence your bored...swing by and do my tranny oil lol k thanks
Old Jan 26, 2013 | 10:49 AM
  #372
Powell Race Parts's Avatar
afaik the only way is to change the gear helix. good luck with that . quaife did one for test. I have it.
Old Jan 26, 2013 | 10:52 AM
  #373
Tjolley's Avatar
CAT has million of gears like this.
Or i can make them not that big of a deal..
How dose urs work?..help any
Old Jan 26, 2013 | 10:56 AM
  #374
mrbelvedere's Avatar
there is no need for it to lock up tighter why try to fix what isent broken
GDS
Old Jan 26, 2013 | 10:59 AM
  #375
GDS
"The only advantage to a gear type LSD is no maintanence or failure due to never locking up 100%.
Quaife for example is a gear type that works very smooth due to the gears which do not stop. There is almost no sound emitted.
Carbonetic’s clutch type has metal disks and high initial torque which makes alot of noise and engaging is very harsh. For delivering power, this is better where the Quaife is nicer for street or track use. Usually people say the Carbonetic is working ON or OFF. This is the only negative for clutch type LSD systems. If you set up the LSD with low initial like the OEM LSD, it will work smooth but the performance is very weak.
The maintenance of the Quaife gear LSD is simple as it almost never breaks. Clutch type LSD’s require oil maintanence and usually metal type LSD’s require the oil to be changed every 3-5K miles even on street driven after the break-in period. The CARBON LSD version requires maintenance more often after initial break-in period. Generally required to change the oil every 2000 miles due to the carbon disks getting dirty faster. So to keep the best performance, you always need to change oil often.
The Quaife gear system rarily break so you do not need to rebuild them. The Carbonetic metal disk LSD needs to be rebuilt every 8-10K miles. Once you lose initial torque, the disk won’t hold well. When they begin to slip, the disks ware out really fast and eventually it will become like a open diff.
The Quaife cannot be set up to different ratio’s like the Carbonetic. A Quaife has just one setting. Clutch type LSD’s can be set up as the customers like, depend on how strong, fast, timing etc. Metal LSD’s are very picky to set up precisely and require a special skill for the set up as you like."
The machine shop does much of our work, that my buddy runs here, makes gears; its his mainbusiness. But realistically, I would not even attempt to try and make different gears, the benefit is so overpowered by the cost, and you sure wont be picking these gears off a CAT shelf.
The hi helix Quaife made for the Time Attack car, John Heinricy did not like it, the car understeered too much for his driving style and he went back to the stock Quaife. I kinda like the hi helix, but I set the car up differently these days, and my Redline is almost 700 lbs heavier than the time attack Cobalt was..
