stroker lsj build
Old Jan 30, 2013 | 11:15 PM
  #401
Tjolley's Avatar
FYI to use half inch studs in an LSJ you not only have to drill the head to make them fit, and of course you have increase the stud bore in the block. I have a scrapped block here, the larger stud diameter weakens the block and ended up breaking it there, at the rear of the block....good luck/ did anyone have an issue with stock size bolts/studs? wondering.
just wondering wondering wat process did u use to install them..
And wat kinda tap did u use to thread the holes.
Old Jan 30, 2013 | 11:20 PM
  #402
Tjolley's Avatar
check this out lol did this awhile ago.
Old Jan 30, 2013 | 11:26 PM
  #403
Tjolley's Avatar
Im not against anything any one has told me
here is a cross section i have of the back holes in a gen2 block.
One is 1/2-13 the other is the 12mm stock size..
There is only .7mm or .027 difference from 12mm to 1/2
Old Jan 30, 2013 | 11:35 PM
  #404
c130aviator's Avatar
there is so much winning in this thread. LOL, that block with those head studs should keep the gasket from failing, i know gm o-ring the cyl when they went over 800 hp but this setup with these head studs sans head gasket should hold to whatever you want to throw at it. I thought I was building my block for more power but you sir are building a tank.
Old Jan 31, 2013 | 07:08 AM
  #405
Tjolley's Avatar
Lol ya i cut apart a good block to get a cross section look at these blocks..
I want to do a gen 1 to compare...
U get urs running
Old Jan 31, 2013 | 07:51 AM
  #406
Powell Race Parts's Avatar
U get urs running
It was Alexx motor. It died a hard death at 347 whp, TVS. I did not install the studs. The motor was pretty much scrap.
Old Jan 31, 2013 | 07:54 AM
  #407
nice picture. thats a lot of work to cut it like that , good for you! Can you show the bell housing end so we can see what material is left? thanks
Old Jan 31, 2013 | 09:58 AM
  #408
Tjolley's Avatar
Sure
Old Jan 31, 2013 | 02:25 PM
  #409
Tjolley's Avatar
here is a lil engine i just finished building all that's left is to take it into the dyno room.lol
its a 40.8 liter engine..lol
Old Jan 31, 2013 | 02:28 PM
  #410
Tjolley's Avatar
Old Jan 31, 2013 | 07:00 PM
  #411
Now thats a saw! lol
thanks for the piktar.
Old Jan 31, 2013 | 07:13 PM
  #412
Tjolley's Avatar
That's our lil one the big one can take a 10 foot cut..
I work in a big boys machine shop.. Takin stuff and making it better is wat i do for a living...mainly engines..
Old Jan 31, 2013 | 07:27 PM
  #413
I think Alexx block was done by JBP who are less than stellar by rep and when I went there on behalf of rwd victory red a few years ago, i found it was a sad place.
But I still am not sure that larger studs are needed, but good luck to your project. I am confident you will do a really top notch job. Not at all like the one we had to fix for an unfortunate customer.
Old Jan 31, 2013 | 07:46 PM
  #414
Tjolley's Avatar
Gm did it without a problem so i figured there is a specific way to do it..it dose involve a lil bit of money for the first one.
Im gona make a thread with most of my findings in these cross sections of a gen 2 block..
Hoping for a sticky!!!!!
Old Jan 31, 2013 | 08:54 PM
  #415
574's Avatar
574
[QUOTE=Tjolley;6909135]Gm did it without a problem so i figured there is a specific way to do it..it dose involve a lil bit of money for the first one.
Hoping for a sticky!!!!![/QUOTE]
Thats what she said
Old Jan 31, 2013 | 09:14 PM
  #416
Tjolley's Avatar
Lmao...oh ya she get that...
Thats another subject i haven't seen a section for that talk yet...lol
Old Feb 1, 2013 | 03:24 PM
  #417
IonNinja's Avatar
Look at that baby turbo!
Old Feb 1, 2013 | 04:32 PM
  #418
Tjolley's Avatar
Ya lol there'd only 4 of them
Old Feb 2, 2013 | 01:22 AM
  #419
armcclure's Avatar
Interesting. I'm in the middle of debugging a robotic cell we made that faces the clutch plates at the Boonville hpmp plant.
Old Feb 2, 2013 | 02:13 AM
  #420
IonNinja's Avatar
oh wow I didn't see the others
Old Feb 2, 2013 | 08:27 AM
  #421
Tjolley's Avatar
I was still waiting on them. 2 on eather side...
That engine is like 6 feet tall.
Puts out 1500hp and 2700tq @2250 rpm not to bad.
Im working on another that even more than that like 3 times that.
Old Feb 3, 2013 | 05:58 PM
  #422
Tjolley's Avatar
Arp oil pan bolts anyone...lol
Old Feb 4, 2013 | 09:05 PM
  #423
Tjolley's Avatar
bolted up my spare header flange and look at all the room there is..lol lots more to do..
Here is most of the part for the 2.4.
Old Feb 4, 2013 | 09:25 PM
  #424
armcclure's Avatar
What's the Trans cooler for?
Old Feb 4, 2013 | 09:35 PM
  #425
574's Avatar
574
Naws!!! :d
