stroker lsj build
Old Sep 16, 2012 | 06:17 AM
  #101
Tjolley's Avatar
Found out wat wheel to use me build...ill have a update with pictures soon..
Old Sep 16, 2012 | 09:44 AM
  #102
JSimons47's Avatar
What?
Old Sep 16, 2012 | 02:22 PM
  #103
Tjolley's Avatar
Reluctor wheel on the crank..
Old Sep 23, 2012 | 07:41 PM
  #104
Tjolley's Avatar
Well i spent a few hours after work the other day cutting up a spare block i had. To do a lil r&d.
Old Sep 23, 2012 | 11:04 PM
  #105
JSimons47's Avatar
Why.....
Old Sep 23, 2012 | 11:19 PM
  #106
Tjolley's Avatar
to find the weak spots and see how close the larger head studs come to the water jackets.
Old Sep 24, 2012 | 10:31 AM
  #107
ebristol's Avatar
cool.
Old Sep 24, 2012 | 12:33 PM
  #108
JSimons47's Avatar
I would have done dirty things for that block you just ruined
Old Sep 24, 2012 | 01:23 PM
  #109
Tjolley's Avatar
is worth just as much in 10 prices...now i can see exactly how it all works and why it does....gota do wat u gota do to learn
Old Oct 16, 2012 | 01:35 PM
  #110
ThexGovenor's Avatar
Any update on this bad boy?
Old Oct 16, 2012 | 02:09 PM
  #111
Tjolley's Avatar
well ive been super busy at work like 14 hr days..
i just got the form tap to mod to block for the 1/2 head studs..Im trading my gm sleeve puller and pusher set for a lsj head. so i can send it out to get it cnc ported larger than the one i have now...the goal will be to have the port in the head flow slightly more than the valve will allow.
Old Oct 16, 2012 | 02:33 PM
  #112
1AJeremyD's Avatar
Thanks for sharing the info on the studs. Definitely sheds some light on the issue to the fullest.
Old Oct 16, 2012 | 02:39 PM
  #113
Tjolley's Avatar
ill have a ton of stuff ones Im done to share.
well the wife oked the tvs 1900
Old Oct 16, 2012 | 03:11 PM
  #114
1AJeremyD's Avatar
Awesome! I would love to see more.
Definitely want to see how this all comes together.
Old Oct 16, 2012 | 03:21 PM
  #115
Tjolley's Avatar
ill be noting all my stuff so i can do this for other ppl...
2.3 lsj 2.4 lsj..
lnf maybe...if any one is interested
Old Oct 16, 2012 | 03:26 PM
  #116
JSimons47's Avatar
Old Oct 16, 2012 | 03:33 PM
  #117
Tjolley's Avatar
as in me sending u model parts for a 2.3 lsj 2.4 lsj strokes..maybe lnf mods also
Old Oct 17, 2012 | 08:25 PM
  #118
wayfarer's Avatar
during our pm conversations, this is the pic I was remembering with welding-- I see the lower ring has some bolts tacked in it, and it appears, other tapered seat holes either drilled, or no bolts in 'em.
this is the LE5 crank "stroker" from ZZP ?
what is the modification?
*EDIT*-- is that the modified reluctor wheel I keep hearing about? so did it start life as LE5 or LSJ?
Old Oct 30, 2012 | 10:50 PM
  #119
Tjolley's Avatar
this is wat i did to my new zzp block today.
Old Oct 30, 2012 | 10:58 PM
  #120
Tjolley's Avatar
look at the bottom of the picture...and yes the bit is one pice no tricks here
Old Oct 30, 2012 | 11:00 PM
  #121
carstedt's Avatar
why did you do that?
Old Oct 30, 2012 | 11:07 PM
  #122
armcclure's Avatar
Dafuq?
Old Oct 30, 2012 | 11:10 PM
  #123
OttawaMark's Avatar
enlarging the oil galley?, pretty sure that is coming out where the oil plugs sit.
Old Oct 30, 2012 | 11:12 PM
  #124
Tjolley's Avatar
bingo...more or less cleaning the hole up...its not a machined hole so i bought a drill just slightly larger than the original hole..
Old Oct 30, 2012 | 11:14 PM
  #125
Tjolley's Avatar
the original hole is casted in the block and is very turbulent...so i cleaned it up to make oil flow better to the mains
