stroker lsj build
Old Jul 17, 2012 | 12:53 PM
Staged07SS's Avatar
Administrator
Administrator
Originally Posted by zrated89
that i happened to have run faster on my tvs than their all out 403 whp stroker motor
just saying.....
You also ran faster times with your M62 setup than most of the 300whp+ turbo guys on here....
Old Jul 17, 2012 | 01:01 PM
zrated89's Avatar
ssshhh although that is true as well
Old Jul 17, 2012 | 05:30 PM
Tjolley's Avatar
Originally Posted by ebristol
ZZP has stated that their LE5 Fidanza Flywheel will work with most LSJ aftermarket clutches.
Also, the LSJ and LE5 have difference reluctor wheels. You will need to swap the wheel from the LSJ crank to the LE5 crank.
Hmm they were tellin me all i would need is a modfied flywheel and to clock it on the crank corectly
Old Jul 17, 2012 | 06:51 PM
ebristol's Avatar
Well...
https://www.cobaltss.net/forums/adva...d-info-252933/
Old Jul 17, 2012 | 08:12 PM
Tjolley's Avatar
Hmm
Zzp sells the crank modified for it already so if i cant do it isnt very expensive to buy.
Thanks for the info.
Old Jul 18, 2012 | 05:57 PM
mrbelvedere's Avatar
Originally Posted by Tjolley
Lol...
The block is getting modified to suport the larger studs..
The block cracks wen larger studs r installed cuz they dont get installed right...u cant just drill out the hole with a hand drill. Each hole has to be dialed in on a mill to ensure perfict center other wise u end up with a side load on the studs that were the cracks form.
correct you are even when done properly the block still cracks because there isent enough meat to support a 1/2in stud that is another reason gm went with the uni bolt studded blocks
Old Jul 18, 2012 | 09:50 PM
Tjolley's Avatar
Hmm ok ill take that into consideration.
Thanks
Old Jul 20, 2012 | 02:21 PM
Tjolley's Avatar
Well i decided to do the zzp girdled block. Cuz i couldnt find a cnc shop that would do the job.
Old Jul 20, 2012 | 03:15 PM
ebristol's Avatar
Not a bad idea. Are you having them build the complete engine?
Old Jul 20, 2012 | 11:10 PM
Tjolley's Avatar
I will...I have faith in them. But rather say I built my beast
Old Jul 21, 2012 | 03:48 PM
  #36
zzp has someone else build the engines they dont do it
Old Jul 21, 2012 | 10:47 PM
  #37
wayfarer's Avatar
does anybody have more details/pics of the girdle process?
I saw the pics from the board member who bought one from ZZP, it appears the process ends at least, with welding the deck closed and milling the deck.
does anybody know what it looks like under the deck?
I'm assuming there's a press fit ring that goes into the water jacket?
Old Jul 22, 2012 | 06:53 PM
  #38
ask zzp
Old Jul 22, 2012 | 07:09 PM
  #39
ebristol's Avatar
Some people believe they machine a plate to the exact size down to the thousands of an inch and press it into the block.
Some people believe they fill the block.
This is a common way people fill blocks.
diy filled b series block, with writeup, comments welcome - Honda-Tech
Only ZZP knows...
Old Jul 22, 2012 | 08:11 PM
  #40
Only ZZP knows...
they cnc cut the top of the block open to match the cnc cut plate that fits in the top of the block then it is tig welded together and then decked to a higher finish standard then gm requires
Old Jul 23, 2012 | 08:05 AM
  #41
Tjolley's Avatar
That was wat i was gona do my self buy the cnc machine at my school is a lil to small to do the job and all the shops close to me didnt seem up to it..ill post up some pics wen the block gets here.
Old Aug 2, 2012 | 07:35 AM
  #42
Tjolley's Avatar
Look wat i found in my garage last night..
Old Aug 2, 2012 | 09:20 AM
  #43
were is the crank
Old Aug 2, 2012 | 09:22 AM
  #44
Tjolley's Avatar
Still witing on it..along with the wiseco pistons
Old Aug 2, 2012 | 09:31 AM
  #45
Tjolley's Avatar
And the girdle isn't welded in and the surface finishes is worse than gms spec
  #46
Axelthered05's Avatar
click
Old Aug 2, 2012 | 10:26 AM
  #47
you wouldent be able to see the welds it after it was milled and the 2 ive seen had realy slick and shiny surface you may need to question them on the finish mill
Old Aug 2, 2012 | 02:14 PM
  #48
Tjolley's Avatar
i can see the machine lines around the girdle...like the way i was gona do it...cnc machine it out and machine a plate to press in.
Im a machines for CAT. and anyone good with a grinder could have surfaces this..its like they did it with a dull cutter.hmm ill defiantly have to ask them about it
Old Aug 3, 2012 | 10:39 AM
  #49
zrated89's Avatar
yea most ive seen have had a better surface than that
Old Aug 3, 2012 | 12:00 PM
  #50
tbellazzi's Avatar
ah so this is what you were telling me about! This looks sick...in for results!
