subaru sound of death question
Old Mar 13, 2012 | 11:42 AM
mrbelvedere's Avatar
when you do a compression the guage has a check valve in it so pressure wont bleed of untill you push the button you should do a leak down test just because your engine shows good compression dosent mean it will pass a leak down test and you could have just had a plug go dead
Old Mar 13, 2012 | 02:33 PM
SaberD's Avatar
i bet your spark plug backed out a little bit. I've had this happen to me on another car, and it caused missing and went rich.
Old Mar 13, 2012 | 03:14 PM
06cobalt racer's Avatar
they were all still tight. i put the socket and extension on and tried to turn them by hand before i took them out and none moved.
Old Mar 13, 2012 | 03:48 PM
SCcobaltSS's Avatar
coil pack possibly
Old Mar 13, 2012 | 04:02 PM
here are the plugs, the are all still gapped at .035 which is what i set them at when i put them in. any thoughts?
number 1
Old Mar 13, 2012 | 07:52 PM
SaberD's Avatar
here is a good website for reading your spark plugs.
NGK Spark Plugs USA
It appears to me that your plugs are dry fouled. Sounds like you should consult your tuner.
Old Mar 14, 2012 | 12:02 AM
running rich
Old Mar 15, 2012 | 07:51 AM
05vue-redline-06ion's Avatar
Originally Posted by mrbelvedere
looks like you had a detonation problem or an over fueling problem
10:1 and didnt get it tuned fast enough.....
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
Builttss
Oct 4, 2015 10:21 AM
jimbofug007
Oct 2, 2015 12:06 PM
