Supercharged SS LSJ/LE5 Hybrid Build
#127
No worries with the rings setting in, did my initial start ups with a 3 step pressure loading for 20min between 2-4k RMPs. Each time letting the engine to reach operating temps then cool down. Also drained the oil and not using synthetics during break-in which is critical
Took the car for 30min drive today in slightly cooler and wet weather and felt a slight hesitation with light throttle and under 1500rpm but pulled through the rest of the rpm range very smooth. No P0300 codes or misfire so suspect the hesitation was a cold air hiccup. Also got less noticeable once the car warmed up
#130
Sweet man.
Nice to see its breaking in easily
#133
It was a hard thing to do but the car is listed in the classifieds, see link below. A steal of a deal and will hopefully go to a fellow cobalt enthusiast who can appreciate the work that has gone into this car.
https://www.cobaltss.net/forums/comp...d-more-306310/
#138
#140
Price reduced on car to $5500 to sell by this weekend. I'm going out of the country again and need the space in my garage. Posted on local Graigslist so if you know anyone spread the word.
#141
Here is the latest pic. Also picked up a 2.8 ZZP pulley and hub from the classified so now thinking 50~60lbs injectors will be needed.
Attachment 40073
Attachment 40073
z28addiction
09-28-2015 12:03 AM
