Supercharger maintenance this weekend!
Old Jan 6, 2011 | 08:03 PM
juice3's Avatar
So sometime this weekend im going to be changing the oil in supercharger, coupler, and bearings. I have boughten the kit and everything i need from zzp. I rented the tool for removing bearings from oreillys, and im gonna grab a torque wrench from a friend. Anyone have tips for me to make this easy? BUT ALSO: anyone know the torque specs on the bolts im taking off like the ten bolts on the snout? I read it before but i forgot...
Old Jan 6, 2011 | 10:49 PM
ebristol's Avatar
M62 Blower Work - Saturn ION RedLine Forums
Old Jan 6, 2011 | 11:39 PM
juice3's Avatar
Good info! Thanks!
Old Jan 7, 2011 | 12:04 AM
juice3's Avatar
Just read 8-12 ft/lb is good for bolts on snout, sound good?
Old Jan 7, 2011 | 07:36 AM
Staged07SS's Avatar
Administrator
Administrator
Originally Posted by ebristol
Nice link man.
Old Jan 7, 2011 | 11:22 AM
neumannl001's Avatar
Ditto on the FYI. Thank you!!
Old Jan 7, 2011 | 11:27 AM
Littlegoose's Avatar
I actually did exactly this last weekend. I ported the outlet to look like the pictures of someone here's steigemeier port job.
Edit: These are the before and after pics I used for reference thanks to Blur.fx:
https://www.cobaltss.net/forums/2-0l...e-after-81643/
About 3oz. came out of the S/C when completely drained. It looked pretty bad. I put 3.4 back in according to eaton's specs.
Take your time if you decide to port and polish, make sure you get all the metal flakes and dust out of their before polishing/reassembly. Also I wouldn't have been able to polish the inlet without a dremel extension, so you might want to look into getting one of those too. Fortunately, BigLots had a 25$ kit that came with 150 pieces including a variable speed dremel and an extension which worked like a champ.
Let me know if you have any questions, but that link ebristol posted above seems to have it all covered.
Also, make sure you blow your engine bay off and clean out the dust/dirt/sand around the intake manifold/fuel rail/supercharger BEFORE taking off the S/C to make sure none of that falls into your intake manifold.
Last edited by Littlegoose; Jan 7, 2011 at 11:34 AM. Reason: Automerged Doublepost
Old Jan 7, 2011 | 11:07 PM
Joemaster70's Avatar
not to thread jack but I have 90k on my car and im going to be doing a low to mild upgrade would a supercharger maintence be required or could it handle a 2.9 pulley 42's tune and meth injec
Old Jan 8, 2011 | 10:00 AM
juice3's Avatar
Thanks little goose for the info!
Joemaster i have read where people say you probably should do maintenance because putting those smaller pulleys will make it work harder so you might want too.. Or at least change oil which doesnt seem hard at all
Old Jan 9, 2011 | 12:30 AM
Erick161's Avatar
subd
Old Jan 10, 2011 | 10:24 AM
juice3's Avatar
I ran into a bit of trouble when i tried to do this, i didnt have good tools!!! so i went out and got like the hex set that can fit into a wrench but now i have school so i have to find time to work on it. Will post immediately when im done with pics
GaryGibblez
Jan 14, 2020 10:35 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
justinchinn
Oct 2, 2015 12:18 PM
z28addiction
Sep 28, 2015 12:03 AM
