swapping walbro 255 too dw300 help
I currently have a 255 walbro installed with a return style fuel system.i believe my pump is going bad and would like to swap to the dw300. Does anyone know if the inlets and outlets are the same? And what is needed to wire it up? A shop installed the current fuel setup but I would like to swap my pumps myself.
First off y did u put a pos walbro pump in?
The stock pump is better and can flow as much if not more than the walbro can.
I hurd u have to cut the bottom of the canister off to use the walbro pump. Not 100% sure about it.
Wat is the car doing to make u think the pump is bad
Sl0wbaltSS
Nov 21, 2018 11:11 PM
ThoR294
Oct 4, 2015 08:44 PM
