Tensioner +Pulley Config?
Old Dec 3, 2008 | 11:57 AM
KillinKrullin's Avatar
Question Tensioner +Pulley Config?
Hey what Tensioner + Belt configuration can i use with a 2.7inch SC pulley
i just recently purchased one from another member here and in process of picking up injectors.
so was wondering if i need a oversized tensioner pulley, if so what size?
Or will it be fine with a stage II belt, or do i need both.
let me know, on account of was about to buy 3inch tensioner.
thanks,
Bill
Old Dec 3, 2008 | 12:21 PM
ShortStack's Avatar
You should be alright with a 2.7 and the stage 2 belt. Im using a 2.8 and ive had no slippage, and it was still tough to get on...
Old Dec 3, 2008 | 01:54 PM
Thanks man, i feel a little bit better
anyone else want to confirm this? i would like to here from a few who are running a 2.7
Old Dec 3, 2008 | 02:02 PM
ShortStack's Avatar
No problem!
Old Dec 3, 2008 | 02:22 PM
papasmurf's Avatar
I *think* you should be fine.
Old Dec 3, 2008 | 02:42 PM
csementuh's Avatar
I run a 2.7" on a Stage 2 belt and stock tensioner. If the belt is worn or stretched, you will get belt slip. If it is a new belt you should be fine. If it slips buy an oversized tensioner pulley or adjustable tensioner...
Old Dec 3, 2008 | 03:04 PM
ok so ill try it out first and the handle the situation if the problem occurs. thanks!
Old Dec 3, 2008 | 05:32 PM
ReckleSS's Avatar
What size is the Stage 2 belt? I have a 2.8" on the way
Old Dec 3, 2008 | 08:54 PM
nherbst454's Avatar
Here's a sample if idler pulleys I make. This is a set for the supercharger idler/tensioner side. They will also probably fit the Cobalt if anyone would like oversized tensioner pulleys.
Nate
www.smoothflowpulleys.com
sales@smoothflowpulleys.com
Old Dec 3, 2008 | 08:57 PM
ptrblkz24's Avatar
Ive been running my 2.79" pulley with the stage 2 belt for over a year now with no problems.Youll be fine with the stage 2 belt.
DarrenGC
Dec 24, 2021 01:55 PM
SmitBag
Sep 7, 2016 08:05 AM
Oct 20, 2015 09:56 PM
justinchinn
Oct 2, 2015 12:18 PM
bobbob160
Sep 15, 2015 11:31 PM
