! Tensioner Troubles !
Old May 2, 2006 | 09:48 AM
codyss's Avatar
I all of my Stage 2 done but I have hit a brickwall, I cannot get the belt tensioner to move.
It says to use a 15mm wrench and I have tried 3 already but they just slip off after about 80% of it's travel.
Is there a secret I am missing here?
Stage 2 injector install = 20 min
Stage 2 pulley install = 1 hour
Stage 2 belt install = 2 hours and counting
Please help!
Old May 2, 2006 | 09:53 AM
2K5SS/SC?'s Avatar
The wrench will slip off if it's not all the way on. I had to literally wedge it on there good. Give the wrench a light tap or two with a hammer to ensure it's seated all the way on the tensioner. Push slowly downward to keep the wrench on and back toward the firewall. It will feel hard at first, and then it'll be easy when you overcome the spring tension. Good luck.
Old May 2, 2006 | 01:54 PM
codyss's Avatar
Thanks!
Old May 2, 2006 | 01:56 PM
2K5SS/SC?'s Avatar
Did it work out? I hope so, because Stage 2 is so much fun!
Old May 2, 2006 | 05:35 PM
zinner's Avatar
Moderator Alumni
Yep that tensioner is a bitch. Once you overcome the "tension" it's pretty easy to hold down.
Old May 2, 2006 | 07:46 PM
codyss's Avatar
I think mine was cast to small, I had to lightly file a 9/16 wrench to get a snug fit.
Took about 3.5 second to finish afterwords.
Thanks guys!
Old May 5, 2006 | 07:54 AM
cybcow's Avatar
What do you do when the back side is slightly rounded off. My 15mm wrench was fairly loose and I was able to hammer on a 9/16 and that was good and tight. But without fail once again just slippage. Please help me with some suggestions.
Thanks.
Old May 5, 2006 | 08:55 AM
codyss's Avatar
When I made my wrench I squared it out and shaved the tips off the wrench end, when I was done all of the wrench was touching.
This way it fits perfectly and there is no room for movement.
Old May 5, 2006 | 09:02 AM
memphisr24's Avatar
Just need a little elbow grease
Old May 5, 2006 | 09:04 AM
cybcow's Avatar
Alright. I'll go ahead and give that a try after work. Thanks so much, I can't stand being without wheels
Old May 5, 2006 | 09:13 AM
BLKSS's Avatar
Yeah man, definatley the hardest part after taking the pulley off. Took like 20 minutes just to get the belt on. Once you got the tensioner down its easy to keep it that way. One to hold it down and another to slip the belt on helps.
Old May 8, 2006 | 11:31 AM
cybcow's Avatar
If anyone has extraordinary problems with the tensioner then try this as well if the above methods do not work.
Take a medium size crescent wrench and make it just smaller than the notch on your tensioner. Use a hammer to pound on the crescent wrench all the way until it hits the bottom. Now put on a glove, grab the wrench and push forward. Hopefully it works and doesn't slip off, but just in case it does you have the glove to help save you from another nasty cut / scrape.
Hope this helps.
Old May 8, 2006 | 12:08 PM
djt81185's Avatar
http://pulleyboys.com/cobalt-ion.html
Half way down the page...works like a dream
Dan
Old May 8, 2006 | 06:48 PM
codyss's Avatar
I bet that tool works good but my 9/16 wrench cost me $5 and took 5min to file.
DarrenGC
Dec 24, 2021 01:55 PM
SmitBag
Sep 7, 2016 08:05 AM
Oct 20, 2015 09:56 PM
justinchinn
Oct 2, 2015 12:18 PM
bobbob160
Sep 15, 2015 11:31 PM
