Timing?
Old Aug 9, 2009 | 12:19 AM
  #101
Snakes709's Avatar
yep. 75/25 mix, 7gph nozzle, cobalt addiction h/e and 2 step colder plugs.
Old Aug 9, 2009 | 05:36 PM
  #102
Area47's Avatar
Rent me! per hour
Originally Posted by light'bolt
I wonder if his location has anything to do with his unusual timing
94 octane out of the pump is amusing.
if you can do back to back runs and have zero knock at the afr and timing level. leave it be.
Old Aug 11, 2009 | 09:27 AM
  #103
06black's Avatar
Originally Posted by Zach06CobaltSC
You have never given me a tune??? The lnf base tune that I am using is the other bryans, maybe he got them confused, I don't know the lnf's nearly as well as I do the lsj's hence why I was using that as something to get started. As far as my tunes go I have never even seen a tune from you, even though I would like to. I don't really see a problem with me going around and tuning peoples cars if they are happy with what I am giving them. I make sure there car is safe and not pushed right to the edge, give them a proper afr, make sure there not running to much timing etc, and they have always been happy. It's not like I am charging them an arm and a leg and telling them they will win every race. I'm really not trying to argue with you, but I don't see any harm/foul in tuning peoples cars??
how the **** did you get one of my maps?
this, i want to know.
i keep my sharing to people whom are of the educated lot, you have proven that you are not to that level yet.
the "harm" i see in you useing OTHER people maps is simple, your profiting, and proliferating off other peoples work. all while not understanding why things are done specific ways.
and that, tool, is my biggest pet-peeve.
also to the one who asked, MBT and such are all derived from engine VE vs RPM.
peak torque can be shifted around with advance, however much past 5600 or so and the cam falls of hard enough that you have to kill cylinder fill with fuel in order to support it. but the later that peak hits, the higher your power curve will climb, and to top it all off, every thing becomes more linear as the math for horse power starts to work in your favor. post 5252.
thus your curve should become a semi-horse shoe, as you MUST fallow cyl pressure for max results. the only way to get a hold of thus mark is time and effort.
this is basic stuff here people, there are no tricks or snazzy formulas.
Old Aug 11, 2009 | 09:45 AM
  #104
sput's Avatar
Thank you!!! It's the basic stuff that I'm still learning
Finally an answer. I'm gonna go celebrate.
Old Aug 11, 2009 | 10:09 AM
  #105
06black's Avatar
go find it on your car.
cyl airmass can help point you in the direction
Old Aug 11, 2009 | 12:13 PM
  #106
Snakes709's Avatar
ok well i got my car re-tuned the other day to adjust the afr that my header/dp/exhaust messed around with. Also my trim was at 25% so we fixed that. im now at 11.9afr and 25* of timing. Still havent seen knock and iat2 got to 149* after 3 pulls on the highway in 27*C weather. Man that TVS just wants to keep making power...lol
Old Aug 11, 2009 | 01:52 PM
  #107
Jrhdpaintball's Avatar
mine as well... which is why i cant wait to put my new valve springs in
Old Aug 11, 2009 | 02:02 PM
  #108
Snakes709's Avatar
im thinking that same thing...get valve springs so i can put my rev limit up to 7500rpm
Old Aug 11, 2009 | 02:16 PM
  #109
freakta's Avatar
a few people would argue that you can run that high with stock valves
Old Aug 11, 2009 | 02:33 PM
  #110
Snakes709's Avatar
whether people say u can or cant. I'm not risking it. I'm pretty sure im pushing the limts of my engine as is...im not going to take any more chances in blowing it up. 11.9AFR 25* timing, 20psi boost 7200rpm rev limit is good enough for me on stock internals.
Old Aug 11, 2009 | 04:14 PM
  #111
Area47's Avatar
Rent me! per hour
you can, if you have a low mile engine. you would be surprised at what the stock engine can take
Old Aug 11, 2009 | 04:27 PM
  #112
StockSS's Avatar
i run 7,400 rpm's on stock exhaust and brought it up to 7,400 many times.
Old Aug 11, 2009 | 05:20 PM
  #113
mine is at 7500 with stock springs lol... prolly not the best idea, but ive got another engine ready to go in my car
Old Aug 11, 2009 | 05:28 PM
  #114
BLAZIN07SS's Avatar
I'm too JDM for you
i used to run my car to 7,400rpm
Old Aug 11, 2009 | 11:28 PM
  #115
ebristol's Avatar
What is your meth/water ratio? What size nozzle are your using?
Useta huh?
Old Aug 11, 2009 | 11:29 PM
  #116
BLAZIN07SS's Avatar
I'm too JDM for you
Useta huh?
well its back to stock now.
Old Aug 12, 2009 | 09:54 AM
  #117
freakta's Avatar
i might try to see what 7400 gets me... when i change my downpipe. it could be cool to see an extra couple of ponies
Old Aug 17, 2009 | 08:34 PM
  #118
ebristol's Avatar
Is this a good timing table for a LSJ with a 2.9" pulley and 42s?
Old Aug 17, 2009 | 09:02 PM
  #119
Zach06CobaltSC's Avatar
I would smooth that out. Big spikes like going from 7degrees to 19degrees isn't necessarily "bad" but is harder on the vehicle from what I was taught at least. With the 2.9 and 42lbers I would be more worried about idc's and pw instead of timing personally. Are you using any timing multipliers/adders? What is the total timing the car is seeing on a wot pull?
Old Aug 17, 2009 | 09:12 PM
  #120
ebristol's Avatar
This is not my tune. Its a "custom" tune I pulled off a local car.
There is IAT adders. But they really don't come into play until the car sees 140 IAT. So it has to be on fire.
There are ETC adders that start at 140 and lower. And ETC subractors that start at 248 and higher. Again. They should never be touched once the car is warmed up.
Old Aug 17, 2009 | 10:29 PM
  #121
Area47's Avatar
Rent me! per hour
if you're going for torque that's peachy. sort of.
Old Aug 18, 2009 | 12:11 AM
  #122
Snakes709's Avatar
75/25 mix with a 7gph nozzle. Did dyno tonight. 4th gear pull...281hp 249trq @ 7000rpm. Abit low for some reason. But oh well, most likely selling the cobalt in a few weeks to buy a 370z
Old Aug 18, 2009 | 02:13 AM
  #123
Area47's Avatar
Rent me! per hour
drop down in nozzle sizes. 5gph is enough
Old Aug 18, 2009 | 03:12 PM
  #124
alanoo's Avatar
I'm circuit driving my 2.2 OE valves which are weaker to 8200 rpm at each trackday, with stiffer springs.
Still alive, approx 8000 km and 1000+ km on track with a 12.8:1 AFR.
(In truth, I had a set of SiValves. Intakes are in the engine, but exhausts were crappy and out of tolerances so stuck with OE ones for exhausts...)
06MetallicBalt
Jul 20, 2025 08:47 PM
Fearedbynone
Apr 14, 2016 03:25 AM
biniecki
Oct 25, 2015 02:23 PM
SSLOW06
Oct 1, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
