Transmission FLuid
Old Oct 10, 2008 | 11:06 PM
2006RedCobaltSS's Avatar
Transmission FLuid
Driving home, i shift from 2nd to 3rd and I hear a small noise, all the sudden I hear a loud whining coming from the motor. Get home, thinking its the clutch because you give it gas, it revs up in gear. Well look under my car and there is tranny fluid everywhere... I can't find the hole. It right by the passenger axle where it goes into the tranny. Its still connected though. You think the tranny is gone, or the axle?
Old Oct 10, 2008 | 11:11 PM
Plastic's Avatar
The axles don't have trans fluid in them. Axles only have grease/lube in them (I think). You had to have cracked the trans case somehow, it's probably a really small crack where it's seaping out.
Old Oct 10, 2008 | 11:31 PM
Ok, well then its going back to stock tomorrow. Solid tranny mounts void warranty you think? I have everything else but that.
Old Oct 10, 2008 | 11:58 PM
silver187666's Avatar
greased sealed axles, think long and hard you think you might of hit somthing? or did you do a neutral drop or somthing like that?
Old Oct 11, 2008 | 12:06 AM
No, I went to the the track last friday, did one run, didnt hook. Last time I dumped the clutch. My brother drove it today, but it was doing it when he got back. Right now im putting it back to stock. How hard is it to pull an axle out
Old Oct 11, 2008 | 01:46 AM
Smarty Art's Avatar
Pulling an axle is easy. You will leak tranny fluid so you better have it available because not all Gm dealerships have it in stock.
DarrenGC
Dec 24, 2021 01:55 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
