Transmission FLuid
Transmission FLuid
Driving home, i shift from 2nd to 3rd and I hear a small noise, all the sudden I hear a loud whining coming from the motor. Get home, thinking its the clutch because you give it gas, it revs up in gear. Well look under my car and there is tranny fluid everywhere... I can't find the hole. It right by the passenger axle where it goes into the tranny. Its still connected though. You think the tranny is gone, or the axle?
The axles don't have trans fluid in them. Axles only have grease/lube in them (I think). You had to have cracked the trans case somehow, it's probably a really small crack where it's seaping out.
greased sealed axles, think long and hard you think you might of hit somthing? or did you do a neutral drop or somthing like that?
No, I went to the the track last friday, did one run, didnt hook. Last time I dumped the clutch. My brother drove it today, but it was doing it when he got back. Right now im putting it back to stock. How hard is it to pull an axle out
Iceberg
Sep 29, 2015 12:33 PM
