Tuners running timing
Old Jun 20, 2009 | 09:16 PM
MarqueDo7BabyBalt's Avatar
meth is a wonderful thing. lol. on these cars you really dont want to go past 25 degrees. they dont make anymore power after that, just more heat
oh ok thx alot man...yea meth is next on my list of parts..
Old Jun 20, 2009 | 09:38 PM
383_Stroker's Avatar
Originally Posted by MarqueDo7BabyBalt
dam that is alot..no knock huh?
No knock.. It picks up about 2* of KR if i run 26* past 6500 rpm so i bring it down a bit on top
Old Jun 20, 2009 | 09:58 PM
oh ok..nice..yea im going to see how far i can go with out knock..
Old Jun 21, 2009 | 02:39 AM
Frew's Avatar
really no point on going past 25 degrees of timing with the stock lsj cams, they just dont support power past that much advancement
Old Jun 21, 2009 | 04:38 AM
oh i see..well thx alot guys for the input..im running 21 degrees of timing now with .4 of knock at 6144 rpm at 1.28 g/cyl..so i backed off like 2 degrees there...she pulls so hard now its crazy..until i get meth im not going any further..
Old Jun 22, 2009 | 11:58 PM
stonny9's Avatar
I was running 22 deg with zero knock so I told italianjoe1 to bump it up some but I dont know how much he did and I havent really run it since then to check out the knock
Old Jun 22, 2009 | 11:59 PM
1badBlueberrySC's Avatar
Alot....
Old Jun 23, 2009 | 12:38 AM
Area47's Avatar
Rent me! per hour
more than the average bear.
do not go off g/cyl for "boost" reference. this number can be skewed easy by maf settings.
for an idea.
120kpa is 3psi. give or take a few 1/4 lbs. go off the gauge for quick reference.
Old Jun 23, 2009 | 08:22 PM
Jrhdpaintball's Avatar
im also running 25-26 degrees of timing... pulls hard....
on a dyno how much of a differance would mid range timing help? or not at all?
Old Jun 23, 2009 | 09:03 PM
Area47's Avatar
Rent me! per hour
depends if you want torque or peak whp
Old Jun 23, 2009 | 09:17 PM
  #36
oh **** really..wow..so what if u want torque?
Old Jun 23, 2009 | 09:18 PM
  #37
Torque is a flat timing map......
HP is a ramped up timing map....
Old Jun 23, 2009 | 09:20 PM
  #38
wow..thx..so basically to get the highest torque out of it you would put the same timing thru the rpm band or really close to it?
Old Jun 23, 2009 | 09:22 PM
  #39
Omnigear's Avatar
mid tq 4tw with
high hp on top
Old Jun 23, 2009 | 10:03 PM
  #40
wow thanks... area, if i send you my tune could u take a look at it and see what areas need working on? i PMed u a couple days ago, if ur willing to help
Sean Cummings
Jan 8, 2020 10:17 AM
Barkleyj605
Oct 24, 2015 12:07 AM
Dustin24
Sep 19, 2015 09:28 PM
Adam144
Sep 3, 2015 07:48 PM
Sean Cummings
Tuning
Sep 3, 2015 03:43 PM
