turbo manifold
Old Jan 15, 2009 | 11:53 AM
  #126
Zooomer's Avatar
Supporting Vendor
Originally Posted by Witt
My source would happen to be the car.
All fuel output from the fuel pump is filtered as a returnless. This doesn't change in a return style setup. What does change is the pressure at what the output is being run at and where its being returned. Since the majority of the time, the car is not under boost, pressure will be lower than the 4 bar constant stock pressure. Lower pressure = more volumetric flow from the pump which equals a higher volume of fuel being filtered in a return style setup the majority of the time.
Your initial claim and link to some e article that is not about this specific setup is weak at best.
Wanna keep diggin?
So the jist of your post is that I lack technical knowledge and make ingorant statements that don't help anyone because I made a comment to the tune of "this style of fuel system may filter the fuel slightly better"? Then I post a link where I got my info and you're saying my defense is weak? It would seem that you're quite hell bent on "proving me wrong" and it isn't going well.
The audience is slamming me for being arrogant, unknowing, etc. but you guys aren't coming back with anything other than generalized slams. I'm discussing physics and have asked repeatedly for some people to look up Bernoulli's principle and not one person has responded. Then I'm called arroagant and stupid for posting that? The only conclusions I can draw are that people don't care and just want to live in the drama or aren't smart enough to understand fluid dynamics. That doesn't make me an ass because someone can't google some basic physics. Then the ignorance is celebrated by a bunch of ZZP bashers searching for ways to 'prove' us wrong in non scientific mannors. I don't speak or think in terms of 'my friends car beat me on a roll after installing xxx part'. To me that isn't a scientic claim, it's just ramblings.
I don't know how to explain things at a more basic level than I have. Does that make me arrogant? I wouldn't think so. When we post flow test numbers from a pump and people don't understand why our numbers are different than another site they read, I cannot keep explaining that units of measure are different but the end result is identical. It's something you need to go back to school for. I can't help if if you don't understand that. I can't help it if you get mad at me for posting data and citing sources. I'm not even trying to sell a product here, just giving out free info that isn't obtainable by the average person. It would be nice to get some credit for providing this free info rather than being slammed for it.
Old Jan 15, 2009 | 11:55 AM
  #127
06blackg85ss's Avatar
you give generalized comments, you get generalized replies....
Old Jan 15, 2009 | 12:02 PM
  #128
djt81185's Avatar
Originally Posted by Scott K.
Please read up on Bernoulli's law or google fluid dynamics.
http://letmegooglethatforyou.com/?q=bernoulli%27s+law
specifically
http://en.wikipedia.org/wiki/Bernoulli%27s_principle
and
http://scienceworld.wolfram.com/phys...oullisLaw.html
I think you really meant bernoulli's principle insead of law since the law deals with fluid behavior at different flows and heights and more specifically their velocity. Really none of these principles deal with increases of FLOW.
Originally Posted by Zooomer
http://findarticles.com/p/articles/m...10/ai_n9426858
My post was based on the filter being located outside of the tank and fuel passing through it at full speed constantly. In the above article you can read about the pros cons and differences based on filter location. I grabbed my info from there and made two additional comments. 1 was that the differences would be small, 2 I used the word may. If you have proof that the return system will increase filtering or make no difference post it up. I have provided my source although this attempt to show me as lacking technical knowledge is weak at best...
http://www.motor.com/page.asp?page_ID=72
Your writer of that article is a ASE certified mechanic. Not a single bit of engineering background there. Is the type of "engineer type technical people in the company" that you have and get your info from? Not to mention some of his stuff in there is a bit off like the returnless not needing a reg, while our system has one. We have both a sock and an after pump filter and since the return kit includes a new filter to replace the stock filter filtration doesnt change.
Wanna keep diggin?
The part in bold is expressly shown in both walbro's charts and zzps own test.
and having a spare fuel canister unit in my possession I can tell you that witt is right that the change in filtration is 0.
Old Jan 15, 2009 | 12:03 PM
  #129
Witt's Avatar
The gist of that post is to show you are wrong in what you stated. That is all.
This is where you can feel free to prove what I'm stating is incorrect.
Old Jan 15, 2009 | 12:15 PM
  #130
Zooomer's Avatar
Supporting Vendor
Possibly so. I stated that a style of fuel system may provide better filtration. If you have a filter and cut it open and analyzed the setup then you should speak up. If you're saying that my assertion of this fuel system possibly filtering better isn't correct then I can accept that.
  #131
unijabnx2000's Avatar
can you get the manifold from the new SS/TC?
would the TC's manifold fit on the SC'd SS's?
Old Jan 15, 2009 | 12:22 PM
  #132
Witt's Avatar
I stated it was not correct and explained why. More fuel being filtered in an equal period of time equals better filtration.
Old Jan 15, 2009 | 01:12 PM
  #133
Maven's Avatar
A full on return fuel system heats the fuel more than the factory setup and may not filter the fuel as well. Granted we're talking small differences here but there are pros and cons to be considered.
I am not sure if this was beat to death or not already.....but its been discussed that generalities and inaccurate information have been used, information has been used to suit the needs of the poster.....I think this filtering comment is a a great example.
You claim that based on your research in MOTOR magazine that a return fuel system may not filter the fuel as well, but in fact the articles first mention of return style fuel system filtering is this "
one advantage of the older returntype fuel systems was the constant filtering of the fuel they provided. Each time the fuel made a trip to the engine, it had to pass through the fuel filter. The filter trapped tiny particles of dirt or debris that may have found their way into the system."
The article goes one to say that 2 of the 3 styles of return fuel systems actually offer very poor filtering....."So if it contains any contamination, the same junk will make repeated trips through the pump and back into the tank. A load of rusty fuel could pass repeatedly through the fuel pump, grinding the rust particles into increasingly smaller particles and making short work of the pump itself." "A filter that's become clogged with debris means the pump now has to suck extra hard just to get the fuel it needs. This causes low fuel pressure, fuel boiling and pump cavitation."
So we see that according to your source theres actually a 75% chance that a return style system will offer superior filtering regardless of flow rates. Interesting.
Old Jan 15, 2009 | 01:16 PM
  #134
ShortStack's Avatar
Nice lookup..
Old Jan 15, 2009 | 01:27 PM
  #135
Matt M's Avatar
Originally Posted by djt81185
Quote:
Originally Posted by Matt M
You quoted Zoom, but must have missed the part where he mentioned "a good majority of the educated people..."
What are you trying to imply here?
That he acknowledged that there are some educated people on the forum as well.
Those examples that you have listed do not apply because you are comparing to a returnless system, which is not what we have. We have a return system that filters the fuel before it is returned to the tank. It just doesn't run all the way to the engine compartment and back. We have all been mis-using the term "returnless." We should not be referring to the factory setup as returnless. Maybe we should call it a short loop return system vs. aftermarket full loop return systems or full length return systems.
  #136
06black's Avatar
so you wanna use a OE cast manifold with a tiny T2 based flange?
why?
Old Jan 15, 2009 | 01:34 PM
  #137
IonNinja's Avatar
Pump--------------------- Flow @ 60 psi--------------------Flow @ 80 psi
Random used GP---------------24.7------------------------------N/A
2002 used GTP-------------------33------------------------------N/A
Walbro 340------------------------50------------------------------30.8
Used Cobalt SS-------------------42------------------------------33.6
Kalo GM truck E85 pump--------54.4-----------------------------39.4
So what you see is that at 60psi, the Walbro does outflow the stock Cobalt pump (06+) by quite a bit which at first would make you think it's better. However, this is usless because both flow enough to provide fueling up to boost levels that you can tune to without a boost referenced system. Once you make the big power, fuel pressure has to change with boost and then the stock pump actually outflows the Walbro when you need the fuel the most (high boost)
out of curiosity, how does increased fuel pressure result in less flow from the fuel pump?
Old Jan 15, 2009 | 01:36 PM
  #138
Maven's Avatar
I know I have been mis-using the terms as well as everyone else. We should not be referring to the factory setup as returnless. Maybe we should call it a short loop return system vs. aftermarket full loop return systems or full length return systems.
Fair enough, youve been misusing terms. Agreed.
Old Jan 15, 2009 | 01:42 PM
  #139
Witt's Avatar
Those examples that you have listed do not apply because you are comparing to a returnless system, which is not what we have. We have a return system that filters the fuel before it is returned to the tank. It just doesn't run all the way to the engine compartment and back. I know I have been mis-using the terms as well as everyone else. We should not be referring to the factory setup as returnless. Maybe we should call it a short loop return system vs. aftermarket full loop return systems or full length return systems.
It is actually a returnless. The term is used for any system that returns before the fuel rail and deadheads the rail. The term is in respect to the rail and not the system itself. Nearly all systems return fuel after the pump in some way (cited from the article here: This is something of a misnomer, as the unused fuel really i; returned to the tank. It just doesn't have quite such a long return trip to make. These systems were introduced in the mid-'90s, and their use is rapidly expanding.) until recently where you can run a pulse width modulated pump, but the article doesnt go into depth on that.
Where the differences in that article play out is simply the location of the fuel filter in respect to the return line. Obviously in a Cobalt, the filter doubles as a junction point for the return line and filters all fuel output from the pump.
Old Jan 15, 2009 | 01:54 PM
  #140
06black's Avatar
its not increased fuel pressure, its increased manifold pressure.
60 being base, no boost (per say) and 80 would be base fuel pressure + 20psi boost.
Old Jan 15, 2009 | 02:00 PM
  #141
qwikredline's Avatar
So to summarise:
ZZP dont like their customers.
ZZP think the forum audience is against them
ZZP make mis-statements.Did I say that right? Technically inaccurate, bs baffles brains stuff.
zzzzzzzzzzzzzzzzzzzzzzzzzzzzz. wake me up. NO thanks ZZP
fortunately, I have an OTTP fuel system, great value, works just fine, so I really dont need to worry. I dont know anything about that. I do have an Option B h/e system with a GM factory dual pass h/e and a single pass laminova. That works great, also you can buy them from OTTP. Well, you can see where this is headed:
OTTP really like their customers
OTTP finds that the forum audience likes them
OTTP dont make mis-statements. Their explanations are simple easy to understand and accurate. Takes a lot of thought to explain things simply and accurately. Thanks OTTP.
SO
ZZP FAIL
OTTP WIN
  #142
Matt M's Avatar
Because the regulator is a restriction in the return line that is responsible for the rise in pressure in the feed line. As the pressure rises, it reduces the avilable flow from the pump, while increasing the potential flow from the injectors.
Old Jan 15, 2009 | 02:01 PM
  #143
nice headlights. Wheels are good too....
Old Jan 15, 2009 | 02:04 PM
  #144
Area47's Avatar
Rent me! per hour
We're way ahead of you Area, although your information is accurate for the most part. ZZP dealt with running off the MAF tables in PCMs before the first cobalt was ever sold. This knowledge led us to run a larger MAF tube to lower the frequency at a given airflow and then recalibrate the PCM to compensate. The other alternative is to run a mini-AFC that some of you may remember on ZZPs site years ago. You can PM me Area if you need more details to fix your build and I'll help you out.
im really trying not to be a dick here about this. i obviously don't need help in tuning my personal vehicle. especially when my fuel maps end up on a twincharge car.
when you run a larger "maf" housing, you run into resolution problems in the lower hz range. double edged sword.
my build is just fine, and moving right along with proven knowledge. i do appreciate the concern
Old Jan 15, 2009 | 02:08 PM
  #145
Matt M's Avatar
We've all been calling it returnless since day one. Just because I am open-minded enough to say that maybe we should use a better term for this should not be construed as some type of evidence against us.
Old Jan 15, 2009 | 02:27 PM
  #146
djt81185's Avatar
Going back to this...the educated people I specifically listed are the ones in this thread SPEAKING up against the misinformation. Zooomer said that the educated people and those wanting to learn are the people who are not talking but listening...those are called sheep...they are being spoon fed. The educated ones are the ones actively discussing the topic and proving false information as false or unreliable.
Old Jan 15, 2009 | 02:28 PM
  #147
Maven's Avatar
you stated youve been misusing terms, plural. You werent talking about this one incident I took it, or did you mispeak again?
Old Jan 15, 2009 | 02:32 PM
  #148
ShortStack's Avatar
<-- bahhhhh
but dammit im trying.
Last edited by ShortStack; Jan 15, 2009 at 02:32 PM. Reason: Automerged Doublepost
Old Jan 15, 2009 | 02:37 PM
  #149
Matt M's Avatar
Plural was referring to "returnless" and "return style". Now you are just looking for a typo or trying to catch me using the wrong word choice or puncuation. At that point, you are no longer interested in having a reasonable discussion and simply prefer to just search for insignificant flaws to nit-pick about. It doesn't help any of us.
Old Jan 15, 2009 | 02:44 PM
  #150
ShortStack's Avatar
yeaaa i think thats a little too much.
