Tvs 1900....ottp stg5?
Old Mar 30, 2015 | 07:16 AM
  #451
Staged07SS's Avatar
Administrator
Administrator
Lsj mani's are a royal pita to p&p. One of those things that is hardly worth the cost vs gain.
this.
Old Mar 30, 2015 | 08:17 AM
  #452
Originally Posted by blueLNFftw
Apparently the guy known as Cobalt Fast actually has a FMSR stage 2 transmission. But when I posted a comment asking him about it he ignored mine and answer everyone elses around mine... lol
The FMSR trans does exist a real friend if mine had it. Was great until he blew 5th gear trying to pass someone on the highway with his ZFR
Old Mar 30, 2015 | 08:20 AM
  #453
Originally Posted by Shanman
The blower seems it would benefit from a polish or maybe port matching of the lsj intake manifold, anyone know who might do that work, i know arm does the blowers, but who does the intake mani's?
Not really worth is as said we did it on mine tried to match it to the intake gasket and polished up the main surfaces best we could. I dont think it made a difference but what do i know, i only made 301 whp on an m62
Old Mar 30, 2015 | 08:48 AM
  #454
Josh@ottp's Avatar
I do that work from time to time. I do a little more work than usual on them and they get a single pass at the same time. Every little bit helps.
Old Mar 30, 2015 | 08:57 AM
  #455
^didn't know you offered a single pass! care to PM me pricing/details please?
Old Mar 30, 2015 | 04:01 PM
  #456
Stikman29's Avatar
I also have a guy in one of the car clubs I roll with that has a FMSR built F40. Roy made 717.7hp on a dynojet on 37psi. He cranked up to 45psi but lifted the head. He 2.4L LSJ, stock compression ratio, I believe. He sent me a list of his mods once but i cant remember. He didn't respond on the FMSR comment on fb because he gets tired of people giving him **** about whether or not he actually has it. Shoulda inboxed him he's cool af
Old Mar 30, 2015 | 07:01 PM
  #457
blueLNFftw's Avatar
I don't inbox people to bother them about their build. I was just surprised to hear some one have one lol.
Old Mar 30, 2015 | 08:46 PM
  #458
What he was using for headbolts?
Old Mar 30, 2015 | 09:30 PM
  #459
Shanman's Avatar
^ WOW at that level thought you needed copper HG with SS cylinder rings and larger Main and Head bolts.
Old Mar 30, 2015 | 10:43 PM
  #460
mrbelvedere's Avatar
roy wasent lifting the head it was the bleed port from the head leaking according to his tuner
Old Mar 30, 2015 | 11:51 PM
  #461
JapEatr's Avatar
South Central *********
What is a bleed port?
Old Apr 1, 2015 | 10:41 PM
  #462
the bleed port that goes to the coolant tank
Old Apr 1, 2015 | 10:56 PM
  #463
Stikman29's Avatar
He was using ARP head studs and he told me that he lifted the head. His exact words were "My head tried to take a vacation" "It tried to take flight from the block" Now maybe the tuner knows better, his initial diag was off or he just didn't want to tell me but that's what I got from the camel's mouth. Sorry for the late reply Slowbalt
Old Apr 2, 2015 | 01:32 AM
  #464
Thanks
Old Apr 2, 2015 | 11:45 PM
  #465
Stikman29's Avatar
Np
Old Apr 6, 2015 | 01:13 PM
  #466
Josh@ottp's Avatar
The TVS 1900 on a 3.14" pulley with a stock throttle body and 3.5" intake will max out the maf sensor table by about 6k rpm.
I will be looking into making a 4" maf tube and a complete 4" intake.
If anyone is building an engine for one of these I would recommend low compression, 8.9:1 - 9.2:1, 2.4l of displacement with a good sleeve, and a decent set of cams.
Old Apr 6, 2015 | 09:21 PM
  #467
freakta's Avatar
sounds like my build haha
when will the 4in intake and maf tube be complete... i want one
Old Apr 6, 2015 | 09:29 PM
  #468
you need more cam then what you have
Old Apr 7, 2015 | 11:26 AM
  #469
freakta's Avatar
I need way more cam than what I have. But without the correct setup to utilize the cam it still won't help as much. I've read your posts ��
Old Apr 7, 2015 | 01:25 PM
  #470
armcclure's Avatar
It still helps more than you'd think. I about cried when I pulled mine out.
Old Apr 7, 2015 | 07:22 PM
  #471
it helps but i think better is coming
Old Apr 11, 2015 | 03:24 PM
  #472
freakta's Avatar
cant wait to learn more
Old May 12, 2015 | 09:57 AM
  #473
freakta's Avatar
Any more info on the 4in intake
Old May 12, 2015 | 10:05 AM
  #474
Josh@ottp's Avatar
Once I get a unit in with the 92mm throttle I can figure out what tb fits best and make an intake for it. Middle of next month I should have it finished.
Old May 12, 2015 | 01:09 PM
  #475
freakta's Avatar
Thanks for the info. I can't wait to get one
