TVS Dyno Number's
Old Jun 7, 2009 | 04:50 PM
Jared B's Avatar
TVS Dyno Number's
Cobalt+SS%2fSC+(TVS)
280hp 240Tq
Mods
-8lbs Fidanza Flywheel
-Spec Stage 3+
-60lb Injectors
-3" ZZP CAI
-ZZP Headers
-ZZP Catless Downpipe
-Megan Racing Cat-back
-DualPass No Opition B or FMIC
-Stock Mounts w/ Inserts
-LS4 TB Ported & Polished
-Harrop 1320TVS Supercharger
I'm have some problems with the LS4 tb goin back to the stock one and goin back for more tunin on saturday.
Old Jun 7, 2009 | 05:20 PM
Bika's Avatar
Fail Less.
wtf is with all the low dyno #s for the tvs cars lately? < 300whp hardly sounds worth it.
What pulley are you using?
Old Jun 7, 2009 | 05:23 PM
Jared B's Avatar
80mm but ls4 tb isnt workin out im losin power with it.
Old Jun 7, 2009 | 05:24 PM
Snakes709's Avatar
im thinking that same thing, im still paying my tvs off from the group buy....making me second guess getting it. I know its all about the tune but damn. So to the OP would you not recommend the LS4 and 3" intake?
Old Jun 7, 2009 | 05:25 PM
G85 SS's Avatar
280/240?? Hummmmmmmm
Yea, they are really tricky to get to work properly. Most people tend to stick with the LSJ TB.
Old Jun 7, 2009 | 05:28 PM
Jared B's Avatar
goin back saturday for another tune with the stock tb it should hit 300. the car doesin really have that much tuning rate now.
it sucks i hate it.
G85 SS's Avatar
AFR and Timing??
Old Jun 7, 2009 | 05:31 PM
Jared B's Avatar
who know wat the afr it wasnt readin rite. there is 15% more fuel then my other tune. he did put any timing.
Old Jun 7, 2009 | 05:37 PM
italstalnprd86's Avatar
280 hp on stock head and cams is impressive to me, how much boost you running with the tvs?
Old Jun 7, 2009 | 05:38 PM
Zach06CobaltSC's Avatar
I am going to make some suggestions for you. Get methanol injection and hptuners and then you will be set. If you don't know how to do the tuning yourself people can send you base tunes or sell you "canned" tunes so to speak over the internet that you can load onto your car.
I see a lot of people getting dyno tuned and the car is not making NEARLY the amount of power that it should and the tunes are crap. Is your tuner using hptuners or some no name program?
With meth injection your going to be able to push more timing and these cars love timing. If your on the stock timing map that would explain why your not putting down a lot of power. I am on the m62 and putting down the same numbers but more torque.
Ask your tuner how much timing you are running and let us know.
Old Jun 7, 2009 | 05:39 PM
lsjwannabe's Avatar
280hp 240Tq
Mods
-Spec Stage 3+
-60lb Injectors
-3" ZZP CAI
-ZZP Headers
loose the megan, get opt b, get a h/e. Throw more timing it and lean it out slightly and you should be closer to that number.
Jared B's Avatar
20psi it had to unplug the boost bypass silinoid b/c it was hittin 15psi an the drop to 10 at 5k rpm
Old Jun 7, 2009 | 05:40 PM
Maxim_X's Avatar
Nice Jared. She's got more in her. But, probably not as much as mine
Old Jun 7, 2009 | 05:44 PM
Jared B's Avatar
wait till saturday im goin bac to smg
Old Jun 7, 2009 | 06:01 PM
Doc's Avatar
Doc
you're easy...
I got 282/281 with a M62
Old Jun 7, 2009 | 06:02 PM
Deathscythe's Avatar
I put down 287/262 just from swapping over the tvs from my m62. Tuning and timing will get you past 300.
Old Jun 7, 2009 | 06:18 PM
Jrhdpaintball's Avatar
im going to get mine dynoed soon... running quite a bit of timing as well.... will there be any noticable differance between 5gph meth nozzle and a 7gph?
Old Jun 7, 2009 | 06:21 PM
scott allen's Avatar
well then whats everyone doing wrong? if i dont put down atleast 320 whp im going to be so pissed off.
Old Jun 7, 2009 | 06:22 PM
Darkmanx's Avatar
Didn't thru tell you the ls4 would cause problems?
Old Jun 7, 2009 | 06:25 PM
Doc's Avatar
Doc
you'll be disappointed at first....keep at it, it'll come.
Old Jun 7, 2009 | 06:31 PM
Spectral's Avatar
If your on the m62 you are not going to get to that number unless you put a **** ton of work into the car.
Old Jun 7, 2009 | 06:35 PM
Think if it like tuning for 60# injectors as opposed to the 42's that come with a stage 2 kit. A lot of things are skipped over just to get it to work, instead of figuring out where the engine/blower combination is most pleased at. Obviously, that depends primarily on pulley size if cooling mods aren't part of the equation just yet. Once you find the happy spot, you push on from there monitoring things as you go. The amount of time spent dialing in things usually determines how hard and how well it runs. It's an animal that needs to be respected, and patience has to be a part of the process. You won't get far without it.
Old Jun 7, 2009 | 06:37 PM
mkulrey13's Avatar
nice jarad..but im still faster then you and im stock with tune
Old Jun 7, 2009 | 06:39 PM
Jared B's Avatar
u might have more power but u cant drive 13.7
Old Jun 7, 2009 | 07:53 PM
OOOOOOOO! lol
youll get good numbers out of it just be patient, freds good
Last edited by 07MetallicSC; Jun 7, 2009 at 07:53 PM. Reason: Automerged Doublepost
