TVS Dyno Number's
Old Jun 8, 2009 | 12:48 PM
  #51
ShortStack's Avatar
Originally Posted by scott allen
how do you know your losing power with it?
Air reversion.
Old Jun 8, 2009 | 12:56 PM
  #52
Zooomer's Avatar
Supporting Vendor
Originally Posted by Jared B
Originally Posted by Tennpenn83
K&N Typhoon CAI
LS4 tb
TVS with stock 3.1" pulley
79 lb/hr injectors
NGK BKR7E's gapped at .035"
Diamond Forged pistons (9.5:1 no coatings)
Cometic Head gasket
ARP head studs
GM dual-pass intercooler endplate with Opt B
CX racing dual pass heat exchanger
ZZP mid-length header/cat-less 3" downpipe/ full 3" exhaust
(mostly) my tuning with HPT
I hit 284.8 whp
I dont have the sheeys yet because i left the car their for clutch install and axle in stall.
It put down 290 whp the tq was low at only 250 lbs wich is due to the full 3" exhaust and no cat. ill have the sheet in a few days and it was on a mustang dyno wich i hear reads low so i dont know.i thought it would do better.
Originally Posted by Deathscythe
I put down 287/262 just from swapping over the tvs from my m62. Tuning and timing will get you past 300.
Originally Posted by Doc
you'll be disappointed at first....keep at it, it'll come.
Only if you expect to dyno higher than 300 on pump gas.
Originally Posted by Rodimus_Prime
280 your first time out isn't bad. I did 278 my first time out, made some changes over winter, picked up 20hp.
...Don't worry about all the folks on here thinking you should be making 300+ right off the bat.
That's what I've been saying and getting mocked for.
I think people can learn a lot from this thread and others like it. Pay attention to what people make with mods and expect the same thing. It's not a lie, it's not controversial or doesn't have to be. It's just common sense and intelligence.
Old Jun 8, 2009 | 01:16 PM
  #53
CobaltSS 16's Avatar
Didn't you only hit like 235whp with a 2.8 and 60s on the M62? Not saying it's the tuner, but those are low numbers for the M62 and now the TVS.
Old Jun 8, 2009 | 01:17 PM
  #54
ralliartist's Avatar
it's the stock pulley. Expecting OMG REDICULOUS NUMBERS isn't LIKELY to happen on a 3.15" pulley. How much power do people typically put down with the m62 on a 3.15" pulley? 250 maybe on the high side with 220tq maybe? I'd say 280-290whp with 250+wtq sounds about right.
Pulley down and get aggressive with the tune if you want more power.
Old Jun 8, 2009 | 01:51 PM
  #55
G85 SS's Avatar
300+ is do-able on the stock pulley. Stock pulley pushes 18-20 psi of boost(I know boost doesn't equal power). Where people aren't getting the numbers, at least in my opinion is scaling the MAF.
If you really want to see results run the meth.
Old Jun 8, 2009 | 01:52 PM
  #56
drew1991sf's Avatar
u act like u kno about the tvs^^^
lol
Old Jun 8, 2009 | 01:54 PM
  #57
G85 SS's Avatar
lol
I don't know everything. I'll sit here and tell you that. But I have done enough reading on it to know some.
Old Jun 8, 2009 | 01:56 PM
  #58
drew1991sf's Avatar
badass, when u gonna race that pos against me for pinks
Old Jun 8, 2009 | 05:43 PM
  #59
Jared B's Avatar
What gear did you do the pulls in?
4th gear
Old Jun 8, 2009 | 05:50 PM
  #60
italstalnprd86's Avatar
Ls1 Throttle bodies are cable driven and not compatible with the LSJ. A 1900cc blower on a 2000cc motor is stupid and inefficient. I've yet to see a single cam for the LSJ thats actually been proven to work.
Hot Rod mag could learn a few things from people on this forum.
considering that hot rod got comp cams, and i called to order some and they have no cores, **** that ****, comp sucks........
Old Jun 8, 2009 | 06:51 PM
  #61
Deathscythe's Avatar
it's not even getting aggressive, the tuning for the tvs just takes time to get right, more time than most are willing to give into the process.
Old Jun 8, 2009 | 06:56 PM
  #62
scott allen's Avatar
3rd gear but we didnt spend no more than a hour on the tune. so i guess 290 and 250 aint bad.
Old Jun 8, 2009 | 07:09 PM
  #63
drew1991sf's Avatar
3rd gear usually reads high
Old Jun 8, 2009 | 07:10 PM
  #64
it's a good gear for dynoing
Old Jun 8, 2009 | 08:45 PM
  #65
Darkmanx's Avatar
should dyno in 4th to get almost true 1.1 people dyno in third because they wanna see high numbers and brag.
Old Jun 8, 2009 | 08:51 PM
  #66
I might try that in a few weeks.
Old Jun 8, 2009 | 11:32 PM
  #67
G85 SS's Avatar
So true. From what I keep seeing on here most people throw it on, get pissed because they are under 300 then scrap the blower.
Old Jun 9, 2009 | 02:12 AM
  #68
Area47's Avatar
Rent me! per hour
no, it's because some people don't want to cook the dyno brakes, nor have insane down time between pulls waiting for the iat2's to come back down.
Old Jun 9, 2009 | 06:51 AM
  #69
Darkmanx's Avatar
lets be real who on this site thinks like that. they want high numbers in third.
Old Jun 9, 2009 | 08:44 AM
  #70
The first time I went to dyno my car, they wouldn't do a pull in 4th gear since one of the guys said our gearing past second is long as ****. So I've just gotten used to the 3rd gear pulls.
Old Jun 9, 2009 | 08:49 AM
  #71
lsjwannabe's Avatar
I made within 1 hp from third to a fourth. Its not for higher numbers its darn close to a wash.
Old Jun 9, 2009 | 08:55 AM
  #72
area knows what he is talking about,thats what he does,me i know nothing about tunning a computer controlled car .I can tune the hell out of a carbed car. Area if you can tell me why my numbers are so low i will paypal you some cash. I dont think anyone around here were i live can tune this car the right way . i know the timing is about right,the afr is about right,i know he took off the piston pertection but thats about all i can tell you until i get the dyno charts from them, i left the car their for the clutch install and axle install,i can do it but the price they gave me ,plus they have a lift i told them to go ahead and do it .$ 375.00 to install my clutch and axles i thought was a good deal,plus my garage is tied up with a few cars i have to work on anyway.
Old Jun 9, 2009 | 09:00 AM
  #73
383_Stroker's Avatar
I made 270 in 3rd and 272 in 4th on sucessive pulls..
Old Jun 9, 2009 | 09:04 AM
  #74
2K5SS/SC?'s Avatar
Ah someone that has a clue! Thank you, as I have verified only a 2whp difference myself.
Old Jun 9, 2009 | 09:14 AM
  #75
Maxim_X's Avatar
I prefer to dyno in third because if I'm running the car and there is a problem with the tune like KR or it's lean the pull is over faster. Back to Back I've seen no variation in peak HP but in 4th I get more power over curve because the turbo spools faster.
