TVS Dyno Number's
that's why i said to get the smallest pulley you can run the tvs safely.....you also might have to lower the rev limit back to 6500 if you go this route. I'm not sure about the Bypass valve being slow though, don't you remember when your car was stock. Ever remember that needle going past 12psi?
There is no reason to lower the rev limiter back down to 6500rpms, the car can take 7k NO problem, 7200 with no issues and SEVERAL people have ran 7500 rpm's for a LONG time without any issues, but 7-7250 is considered "safe" on these motors with or without a tvs.
The only problem with the smaller pulley theory is the fact that it creates A LOT of heat and that the OP would have to run methanol injection with a decent amount of water in it to cool the iat2's down, that in return is less methanol which means less timing.
It's a little bit of a trade off but I am sure he would put down more power with a smaller pulley. If the op's head isn't ported I would HIGHLY suggest it because then you will be looking at roughly 330whp with a solid tune.
So your telling me if I set the boost reduction to only 50% in 2nd gear a person who normally boost 20psi would not boost 10psi? I think not. I have tried, tested and proven that boost reduction in hptuners DOES in fact work. Granted the TVS applications might be different as I have never "personally" tuned a TVS before, however boost is boost and limitations from ecu's are limitations from ecu's lol.
and you blower will spin at that velocity all the time its not very good for it. yes you can get a "safe" pulley but its still gonna spin alot faster than normal an
thx Zach and btw i wasn't talking about the rev being turned down for engine protection i meant to keep the supercharger from spinning too fast. I remember going to 2.5" on the M62 + 7K = M62 going out of tolerance. Don't know what it is on the TVS though.
To be honest with you people say anything under a 2.8 isn't "worth" it on an m62. I personally agree with this statement. Anything under a 2.8 on the m62 you are create way to much heat and really aren't seeing much gains. Now with the TVS I personally have known people to run the SMALLEST pulley that will fit on that s/c without headaches. There is no reason why you can't run 27lbs of boost right area?? *wonders if he's lurking this thread*
Area is and exception to the norm. People shouldnt take his results as typical and expect the same with their runt-of-the-mill, out-of-the-box TVS set ups. It will lead to dissapointment as I have seen with many people.
really?
go sit in the corner.
I meant your tuning is the exception.
The vast majority of tuned cars that I saw at a local dyno day failed miserably.
2.7" and 2.8" pullied cars with water/methanol, 3" exhausts, etc. putting down only 245-250
TVS powered cars putting down only 280hp and 240tq with big h/e and full 3" exh.
The high number of the day went to a ms3 with only a cobb intake and larger i/c. (298whp 300wtq)
?Que' Pasa?
I've never seen anyone else put down 350+ on a tvs cobalt. IMO the rest of us just fail at tuning.
bryan's tuning=
.....and people think i'm crazy for driving 7 total hours for tuning.
I realize that, but I'm just going by what i have seen or read on this forum.
My point exactly.
thats because byan has the only "area tuned" tvs car silly. i just can't wait till i get the tvs on my car. i made, what was it bryan like 230 or 231wtrq?, on a low reading dyno with the 2.8, which i remember you telling me is better than what you got with the 2.7
bryan's tuning=
bryan's tuning=
yeah i normally syncronize my trips to topeka with intstalling **** on my car. so, every time i go to topeka, i'll head over to kc and have him tune it and meet up with some other members. last time i went up there me, cobalttc05, revhigh18, and elite cyborg went to heartland park and did some racing
well enlighten us then, assuming your redline was still 7000, whats your peak hp # then?
on a completely stock motor (that means never even taking off the valve cover) and 93 octane like most of us actually have, I don't care who tunes it you won't get 350whp except maybe on a really generous dynojet an even that is completely unrealistic
I'm so sick of what these TVS threads turn into. People need to quit bitching about low numbers, learn how to tune for themselves by trial and error and not sit in a corner griping on why 1 person makes 340+ to the wheels while another can't break 280.
This forum is so full to argumentative bullshit it's not even funny. I'm not singling anybody out or directing this to any 1 person. I'm just tired of seeing the constant e-fighting because people think they know it all.
why expect any more than 300 with the "stock" TVS pulley? 90% of TVS owners are still on teh stock pulley. almost all of the "TVS dyno #'s" threads are on base tunes from ott with almost no individual tuning done. that's it. until there is more time spent on the tuning, then no, you won't see over 300. drop pulleys, do supporting mods and tune like a **** and you'll see well over 300. i imagine i'm there already
