tvs dyno results
Old Jun 12, 2009 | 04:17 PM
  #101
Pyros777's Avatar
The question youre asking does not have a straight answer.
Each of the different types of dynos can be configured by a human. That human can make any dyno read inaccurately. For instance I just dynoed on a Dynocom chassis dyno. Who the hell has ever heard of Dynocom?? Well I hadn't, but it gave me reasonably accurate numbers based on my mods and weather that day.
This is why you should have done a baseline first.. with mods that 90% of LSJ owners have dynoed with (stage 2). Now you are stuck wondering whether your numbers are right, when in reality that doesnt even matter.
You need to stop dwelling on the numbers, and focus on getting the tuning straight because that torque number does seem a little low IN PROPORTION to your hp number.
Old Jun 12, 2009 | 05:10 PM
  #102
Area47's Avatar
Rent me! per hour
Originally Posted by Rodimus_Prime
so very NOT true
for instance my last trip back in october where it was only 107x you can't get an accurate idea of trap speed if during the pass your having to let off the throttle almost completely several times during the pass.
Trap speed is only a true indicator if you have the perfect pass, which theres alot of supporting mods you need to make that happen with a 300whp car.
your traps speeds are slower than what i was doing on a stock m62 w/2.7.
hows this for trap speed fun.
last time to the track. i pulled a 1.9 short time, went to hit second and blew through the clutch. jumped in and out of the throttle 4 times, said **** it and shoved it in third. this landed me at 2500-3k rpms. hammered it. clutch fought me till about 4500 then grabbed. still trapped 111.89mph.
with your 298whp, you should be doing that with ease.
so, you want to explain to me what is going on in your head?
Old Jun 12, 2009 | 05:12 PM
  #103
Maxim_X's Avatar
Originally Posted by Area47
trap speeds with a moderately good short time will tell more than a dyno will
x 100. When you compare dyno's from across the country you can argue all you want about power the car makes and why 1 car is better built that another. But, when you get down to it the only way to know is to line compare the 1 thing that doesn't change, the distance of a 1/4mile.
Last time I went to the dyno I got 310whp. Not very impressive I know. With some tweeking at the track I estimate I was sitting at 325whp. I consitantly got between 112-114 mph and kept it in the 12's. That's on a full weight car.
Old Jun 13, 2009 | 01:42 AM
  #104
2K5SS/SC?'s Avatar
1. You should only compare your dyno numbers to a previous dyno you have laid down on the same exact dyno setup the same exact way with roughly the same exact weather.
2. Track times do indeed tell a story as to how fast a car really is. There are certain numbers on that printout of your run that are more important than others depending on what you are using it for.
Old Jun 13, 2009 | 09:35 AM
  #105
Jrhdpaintball's Avatar
yea... can i get one of those tunes.... please
Old Jun 13, 2009 | 09:42 AM
  #106
scott allen's Avatar
well i got in my first race last night. It was a 81 camaro with a 396 big block , intake,mild cam,carb,headers,flowmasters,and gears,we did it from a 40 roll i pulled by a fender right off the bat then i had a little trouble getting it in 3rd but i got it in there and put about 6 cars on him.
Old Jun 13, 2009 | 12:16 PM
  #107
younchamp's Avatar
Nice!!!
Old Jun 13, 2009 | 02:12 PM
  #108
freakta's Avatar
nice kill. how do you think you would have done from a dig
Old Jun 13, 2009 | 04:04 PM
  #109
dont know i dont want to kick on it in 1st gear because im trying to break the clutch in . He said he spins alot in 1st also so i dont know. drivers race on launch i would guess.
SmitBag
Sep 7, 2016 08:05 AM
Jan 12, 2016 12:01 AM
maliki778
Oct 1, 2015 07:39 PM
SSLOW06
Oct 1, 2015 07:21 PM
Sep 27, 2015 08:53 PM
