Tvs Install Help
Read this:
https://www.cobaltss.net/forums/2-0l...9/#post4831102
In a nutshell, the part number all the parts stores list is WRONG.
This is the part you need:
90423637
90423637
#36
Bump from the dead.
Does any one know if the wiring that connects to the tmap is the engine harness? If not what is the part number for the wiring. I fucked mine up when I installed my tvs and now it's giving me grief.
#37
Yes it is part of the engine harness. Do you just need a new connector to connect to the TMAP?
If so you can just get one of the pigtails that the LNF guys use for the GMS1 sensor and splice it into the wiring.
This should work:
Amazon.com: ACDelco PT1863 Crankshaft Position Sensor Connector: Automotive
Nevermind that it says crankshaft position sensor, that is the same connector as the TMAP. Its part number PT1863.
This should work:
Delta coupe
09-30-2015 08:11 AM
