To use anti-seize or not?
Ok, I am going to be installing a set of Zex plugs tomorrow, and I need to know if I need to put anti-seize on them... I have searched and read, and mostly I get people who are bitching at each other with yes, no, yes, no, etc etc....
And, if I do need to put it on there, how much? How should I apply it? I changed the plugs in my last car (1998 Honda Accord 2.3l) and I didnt use anti-seize then, but I didnt care nearly as much about that car
And, to tighten them down, I read 15 ft-lbs to torque them to? or 1/4 turn past finger tight? Which is it?
Thanks in advance.
Thanks in advance.
I never put aniti-seize on the plugs when i insall them.I never had a problem with removing them without it.If you have some,you might aswell put some on.When you tighten them down,just snug them.They dont have to be too tight.
I use just a dab of anitseize and spred it into the threads carefully with my finger. Do yourself a favor and get yourself a printout of the torque specs or search on here for the full list someone posted, and BUY A IN.LB. TORQUE WRENCH! Everyone please stop guessing on turns and tightness, and torque things to spec so they don't break or strip out! Make sure the car is cold when doing so as well.
Okay, backyard mechanics say don't use anti-sieze and don't use torque specs.
What does your head tell you?
Ofcourse you use anti-sieze on spark plugs. That's why it exists. And the torque for plugs is 15 ft/lbs.
well, I put them in without anti-seize, and they threaded in fine. It didnt look like the old ones that GM put in had any on them either. From what I understand they seize up up if you leave them in too long, so I'll check them periodically. Also, I read from manufacturers that said not to use anti-seize.
The car idles ALOT smoother now, I mean like to the point where I had a rattle go away... Seems like it runs a little better at higher RPM's as well. All in all a nice little investment I think. Thanks for all the input guys, greatly appriciated!
nope dont need. it the plugs wont rust, and its alumminum block threads. but they could get seized on from corosion. but i doubt it there covered over pretty good from the 2.0s or 2.2s the 2.4s have coil packs on top.
ryan.
ryan.
Alot of people OVER USE it and it gets on the insulator and misfires and it can also actually melt and drip down into the chamber. Also if used the plug torque should be lowered due to the threads are no longer dry (which most torque values are with dry threads).
If you use it just a very small dab is all that is needed. Once you break a plug off in a alum head then you will realize why its used, but I only use it on alum heads as I have it laying around and it sure doesn't hurt anything to use it.
Just flip a coin I say....
Yeah, I think I am going to keep an eye on them, pull them and check them at oil changes to check for corrosion, wear, etc etc... I do see your point about people over using it though
2.0 LNF Engine: How to for CIA Down pipe...warning - big pics!
Nakaiya21
How to Guide
68
May 31, 2012 10:48 AM
