Weird problem
Old Jun 23, 2010 | 08:16 PM
hawkssoccer11's Avatar
Weird problem
Ok. so i got the zzp stage 3 installed about three weeks ago. It works great, except i was taking my cousin for a ride and i was in 3rd and around 5k it felt like something was slipping and my check engine light blinked 3 times and went off. It also did it in 4th gear about the same rpms. what is it?
Old Jun 23, 2010 | 08:34 PM
yamaha288's Avatar
dude its your fuel map its got a bad hole couple more milaseconds of timeing and youll be running 9's
Old Jun 23, 2010 | 08:42 PM
ok. but it just started about two days ago and never did it the first two weeks.
Old Jun 24, 2010 | 02:52 AM
skatin_boarding's Avatar
Sounds like a maf problem. Any one have hptuners around you that could help you out? You should get your afr checked out either by a wideband purchase (recommended) or get to a dyno and get a readout of it. In my experience the "falling flat on its face" comes from a rich spike.
The blinking cel is a misfire iirc.
Old Jun 24, 2010 | 02:54 AM
OneCOLDBIZL272's Avatar
if the cel flashs isnt i thought that ment your car saw a misfire correct.
Old Jun 24, 2010 | 09:51 AM
yeah thats correct. I just wanted to see if anybody knew what it was from previous experiences.
Old Jun 24, 2010 | 09:59 AM
coopercharge's Avatar
Did you make sure to oil up the injectors orings when installing them? If not it may not be getting a good enough seal. Also check all of your vacuum lines as if they are cracked or have holes in them it could be causing the problem. Did the check engine light stay on or is it off. If so check the code and find out the issue.
Old Jun 24, 2010 | 11:56 AM
it just flashed 3 times and just went away
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
yellow dragon
Sep 28, 2015 09:49 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
