what would be safe
what would be safe
Okay guys. Im wanting to go smaller pulley and larger injectors.. Thing is I don't have a tuner in iowa, nor one close enough to me. Now I know gm has stage 2 but its way overpriced. What im wondering is what would be a good size pulley kit and 42's with gm's "reflash" because from what I've read I can go to the dealership and ask for the latest reflash for like 100 bucks or so and its the same as the stage 2 tune.. Is that true?
Bump.... no one?
Bump.... no one?
Last edited by shsballa023; Jun 11, 2008 at 07:31 PM. Reason: Automerged Doublepost
check out this thread:
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/problems-2-9-pulley-116424/
we've been discussing the effects of the 2.9 on 42's. It depends where you live but a 2.9 is pushing them to the max. My suggestion would be a 3 inch.
No you have to buy the stage2 kit to get the reflash from gm. The kit comes with a code that they use to download the reflash for your specific car.
Edit: actually though the stage1 reflash is the same.. you could just buy stage1 if you still want gm's tune. The dealer should reflash for around $100.
you have to buy the stage 1 or 2 kit to get that flash. i would suggest looking for a good deal on a stage 1 kit on ebay or something, that comes with the injectors and the code for the flash. then you can just buy your own pulley and belt
If black06 has already tuned your car he could get a stage 2 tune from HPTuners. Of course make sure you have all the required parts, 42# injectors, belt, pulley, hub, bolts etc and he can flash it on since he's already licenced your car with his HPT.
If I was closer I'd do it for the cost of credits, I've got a GM 06 stage 2 tune on my computer. But I'm at least 10 gallons of gas away from you.
The other thing you have to think about is if later down the road you take your car in for maintenance and they flash the PCM back to the stock tune because they suspect a problem with it. Just some thoughts....
Macgyver2484
Sep 2, 2015 05:44 PM
