what would be safe
Old Jun 11, 2008 | 07:31 PM
shsballa023's Avatar
what would be safe
Okay guys. Im wanting to go smaller pulley and larger injectors.. Thing is I don't have a tuner in iowa, nor one close enough to me. Now I know gm has stage 2 but its way overpriced. What im wondering is what would be a good size pulley kit and 42's with gm's "reflash" because from what I've read I can go to the dealership and ask for the latest reflash for like 100 bucks or so and its the same as the stage 2 tune.. Is that true?
Bump.... no one?
Last edited by shsballa023; Jun 11, 2008 at 07:31 PM. Reason: Automerged Doublepost
Old Jun 11, 2008 | 07:34 PM
chevysssc's Avatar
2.9 is always a good choice
Old Jun 11, 2008 | 07:54 PM
sput's Avatar
check out this thread:
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/problems-2-9-pulley-116424/
we've been discussing the effects of the 2.9 on 42's. It depends where you live but a 2.9 is pushing them to the max. My suggestion would be a 3 inch.
Old Jun 11, 2008 | 07:59 PM
chad463's Avatar
Yah I found that 2.9 pushed my injectors over 100% so I ordered 60lb injectors. I would say stick with a three inch.
Old Jun 11, 2008 | 08:04 PM
Thanks guys.... anyone know about the gm reflash tho?
Old Jun 11, 2008 | 08:05 PM
sput's Avatar
No you have to buy the stage2 kit to get the reflash from gm. The kit comes with a code that they use to download the reflash for your specific car.
Edit: actually though the stage1 reflash is the same.. you could just buy stage1 if you still want gm's tune. The dealer should reflash for around $100.
Old Jun 11, 2008 | 08:17 PM
From what I've read tho you can ask for the latest reflash from any gm dealership...? Am I reading wrong
Old Jun 11, 2008 | 08:21 PM
06_SS_S/C's Avatar
yes you are reading wrong. why would they flash a stock cobalt with a flash made for larger injectors????
you have to buy the stage 1 or 2 kit to get that flash. i would suggest looking for a good deal on a stage 1 kit on ebay or something, that comes with the injectors and the code for the flash. then you can just buy your own pulley and belt
Old Jun 11, 2008 | 08:26 PM
Thanks for the clear up guys
Old Jun 11, 2008 | 08:42 PM
light'bolt's Avatar
If black06 has already tuned your car he could get a stage 2 tune from HPTuners. Of course make sure you have all the required parts, 42# injectors, belt, pulley, hub, bolts etc and he can flash it on since he's already licenced your car with his HPT.
If I was closer I'd do it for the cost of credits, I've got a GM 06 stage 2 tune on my computer. But I'm at least 10 gallons of gas away from you. The other thing you have to think about is if later down the road you take your car in for maintenance and they flash the PCM back to the stock tune because they suspect a problem with it. Just some thoughts....
Old Jun 11, 2008 | 08:47 PM
He's in michigan tho lol. Id be better off driving a full tank of gas to come to you. I will keep you in mind lol.
Old Jun 11, 2008 | 09:01 PM
light'bolt's Avatar
except it wouldn't be a good idea to drive with your new set up this far without the flash. You'd be better off filling my tank with gas.
Old Jun 11, 2008 | 09:45 PM
Well I have someone I could bring with me that would be able to do the install. Or what would you charge to install and tune? I've got an 06 as well
Rduncanss06
Sep 27, 2015 11:17 PM
TylerJHowell
Sep 21, 2015 06:47 PM
ATOMbomb
Sep 11, 2015 10:48 AM
Macgyver2484
Sep 2, 2015 05:44 PM
