Whats the difference?
Old Apr 16, 2013 | 01:26 PM
MrSlickSter06SS's Avatar
The PCM DOES NOT see "2bar" it sees a VOLTAGE SIGNAL that it converts to an absolute pressure on a 2bar scale. It doesn't give a flying **** what sensor you put on.
A 3 bar sensor at its max output voltage will be in the top of the table just like a 2bar. Stop thinking in pressure and think electrically, which is what the PCM uses.
ANYWAY, it's completely irrelevant since our VE doesn't have the rpm range to make it work.
Just please stop saying "you're wrong you're wrong you're wrong" when you don't even understand what I'm saying.
I know what you are thinking. And you're stuck on the fact that the VE table in hpt stops at 2bar. That doesn't matter.
But I'm obviously not explaining it in a way that you can understand so just drop it.
As I said its pointless anyway.
Lol well can you care to answer my questions pretty please? Since you seem to know about the topic at hand..? Thanks!
Old Apr 16, 2013 | 01:29 PM
armcclure's Avatar
Do you have a scanner that can monitor map?
Old Apr 16, 2013 | 02:58 PM
No. Just getting a cel for it.. I replaced the one on top of the sc but it was the wrong one... apparently lol.
Old Apr 16, 2013 | 03:35 PM
armcclure's Avatar
The one on top is the scip (supercharger inlet pressure) usually tries p1182. It's only use is for sanity checks. More or less useless on a modified car.
The map sensor is over by the coolant hose goo g into GE head on the top left of the intake manifold.
Old Apr 16, 2013 | 03:42 PM
mrbelvedere's Avatar
I have been understanding what you are saying mr moose knuckle your not getting why it wont see the voltage changes of a 3 bar the pcm will see x voltage at 21.5 psi you put 3 bar in and when the pcm gets to x voltage for 21.5psi the pcm cant see voltage past that point period you can rescale it all you want
Old Apr 16, 2013 | 06:20 PM
armcclure's Avatar
I give up **** waffle. You still don't get what I'm saying but there's no ******* point in bickering about it because it won't work anyway. Now GO WORK ON YOUR MOTOR AND GET THE MOTHER EFFING GIANT ASS BOX I SENT YOU INSTALLED AND HOOKED UP!
Mrslickster; you need to scan to see what pressure the map is showing with key on car off.
Old Apr 17, 2013 | 10:39 AM
see I told you I was right
Old Apr 17, 2013 | 11:00 AM
armcclure's Avatar
Ugh I hate you you son of a bitch
GDS!!!
Old Apr 17, 2013 | 11:10 AM
blah blah blah blah GDS yo
Old Apr 17, 2013 | 01:05 PM
ebristol's Avatar
Old Apr 20, 2013 | 06:43 PM
  #36
so basically ive replaced the wrong sensors this whole time..? i thought that sensor was the temperature gauge for the coolant..? im so confused..
Old Apr 20, 2013 | 08:41 PM
  #37
armcclure's Avatar
The map sensor is very close to the coolant temp sensor. Like within a few inches. It's in the intake manifold on runner #1.
Old Apr 21, 2013 | 10:50 AM
  #38
Okay I'll take a look thanks dude. Wish I could find a pic just to be sure I am looking at the right thing..
Old Apr 21, 2013 | 11:04 AM
  #39
Okay I found it, what size bolt is that? Looks like its held in by one bolt
Old Apr 21, 2013 | 11:38 AM
  #40
Bump.
Old Apr 21, 2013 | 12:58 PM
  #41
Nvm I sprayed it with MAF Cleaner it was super dirty.. Oily, and grity verynasty cleaned up so I can see the orange sensor within the plastic cage that is surrounding it. See if this works. I hope so.
Old Apr 30, 2013 | 12:34 AM
  #42
c130aviator's Avatar
i like waffles
turbochargedss2012
Sep 20, 2023 12:17 PM
biniecki
Oct 25, 2015 02:23 PM
Oct 13, 2015 09:32 PM
importkiller
Sep 30, 2015 07:18 PM
Sep 28, 2015 12:51 PM
