Where are your water/meth nozzles, tanks and pumps mounted?
Old Dec 16, 2013 | 09:13 AM
freakta's Avatar
A lot of people are running a ton of meth. I've got 4 1gph nozzles. I know guys running 24gph ones
Old Dec 16, 2013 | 09:26 AM
blueLNFftw's Avatar
Thats a big habit.
I have a 3gph and a 6gph.
I plan to install the 3ph and use the washer tank as my fill. Probably a 50/50 mix
Old Dec 16, 2013 | 08:36 PM
06cobalt racer's Avatar
i currently have a 8 gph on my m62 setup. will be using a 12gph on my tvs setup
Old Dec 16, 2013 | 09:01 PM
Bluelightning's Avatar
Got Bewst?
I run 14gph on my TVS set up. The only bad part about running lots of meth. If it stops working it's game over faster than you know it.
Old Dec 16, 2013 | 09:36 PM
574's Avatar
574
You still don't have that on yet? !
Old Dec 16, 2013 | 11:29 PM
lol yeah sorry man. been busy with pcsing from germany to oklahoma and my car isnt here yet
Old Dec 17, 2013 | 01:00 AM
Custom made tank hiding between the bumper support and radiator, pump under and behind the front grille, running the line to the ottp throttle spacer
https://www.cobaltss.net/forums/show...0972&styleid=9
Old Dec 18, 2013 | 09:23 PM
shaman's Avatar
Riceburner, I have some suggestions for your setup. If you are running the pump outside, seal up the wiring where it comes out the bottom. Water ingress kills many pumps.
Second, the vent is a good idea, but you could also use a check valve. I bought a cheap HHO check valve and a 1/8"NPT male to hose bard fiting and attached them via hose to the top of my tank, as the cheap square washer fluid bottle I was using as my tank would drip out if it got too full.
Next, is anyone running any kind of failsafe? The kit I am using has a way to activate a failsafe, but it seems that most put a relay and resistor on the IAT2. I was wondering if wiring into the boost bypass valve would work. It has a resistor that should prevent throwing a code.
Old Dec 18, 2013 | 11:25 PM
Originally Posted by shaman
Never overestimate me Blackstg2. I have made several things that fit not fit before
I had a modded 100psi pump from Devil's Own. Just commenting because there doesnt' seem to be many around anymore? is your modded for higher pressure?
no it is the stock pressure. how do you mod them?
anyone??
Old Dec 18, 2013 | 11:44 PM
shaman's Avatar
Its on the Devils own website. Just need a washer to install in the pressure regulator on top of the pump. If I was at the computer I could probably define it better with pics. Have you had the top of the pump apart? You're just shimming a plastic piece connected to a spring.
Old Dec 19, 2013 | 12:30 AM
  #36
I have a checkvalve between the pump and the nozzle. I think my pump or boost controller failed because one day it straight up started injecting while i wasnt in boost so i bought a new setup to install this winter.
This time i got a floater so i dont have to worry about the levels, and plan to isolate the pump better probly in the bay somewhere.
As for the failsafe it depends how you are tuned for meth. If it is a tune that depends on meth as a fuel source then id have it switched according to the pedal position and afr. Otherwise yeah iat2 would be a good one. As of now i got no failsafe
Thanks for the tips
Old Dec 19, 2013 | 12:31 AM
  #37
anyone??
The devils own pumps usually run 250 psi i thought
Old Dec 19, 2013 | 07:46 AM
  #38
shaman's Avatar
I was referring to a check valve on the tank to reduce vacuum in the tank.
I was planning on getting tuned for the water method, just need to decide which kit, where the nozzle will go (hoping to find a place after the IC), and how to hook up the failsafe ( hoping interrupting the bpv will work)
Old Dec 19, 2013 | 10:08 PM
  #39
looked through the site and couldnt find it
Old Dec 19, 2013 | 10:21 PM
  #40
shaman's Avatar
150psi pump mod
Old Dec 19, 2013 | 10:29 PM
  #41
thanks!
" if your nozzle is smaller than a 5 you can shim it for more pressure. If its larger it will not help."
damn, wont help
Old Apr 19, 2014 | 11:20 AM
  #42
shaman's Avatar
You can put the Cobalt Washer Fluid tank in the IRL but you cannot put the IRL washer tank in the cobalt. No space because of the intake routing and brackets.
If you have an IRL this works. Putting the cobalt washer tank in the passenger side of the compartment.
I have been working with Richard at Aquamist to figure out the failsafe, have a TB spacer on the dresser, and 20ish gallons of meth.
Did the cobalt tank require any special parts for installation? I haven't seen how it is installed in the cobalt up close, so I have no way of knowing what bolts screws, etc are going to be needed.
Old Jun 13, 2015 | 10:54 AM
  #43
shaman's Avatar
Bringing this back from the dead, as I need to know where people are tapping the MAP sensor. 2005 Redline if it matters.
Old Jun 13, 2015 | 11:12 AM
  #44
Blairwolf's Avatar
Map sensor has 4 wires going into it. You want to tap into the grey one. It is wire #4 and should be on the right side.
Old Jun 13, 2015 | 11:19 AM
  #45
shaman's Avatar
Thanks Blairwolf. Would that be wire number 5 of the C2 connector?
Service Information
Old Jun 13, 2015 | 11:56 AM
  #46
Blairwolf's Avatar
I tapped mine right at the map sensor. But that looks like the right wire from the diagram.
Old Jun 13, 2015 | 12:48 PM
  #47
shaman's Avatar
It's tight in that area. Hoping to run that wire with the second stage solenoid near the TB.
Jan 12, 2016 12:01 AM
OrangeCoba
Oct 1, 2015 10:00 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
