who would be interested in a semi- built shortblock?
Old Aug 1, 2013 | 10:18 PM
  #101
kxrida2000's Avatar
It sat for multiple months. A few small pieces of debris could cause that. If it was a few score marks I could understand but there are literally 50 or more. Where did 50 score marks come from if u said there were only a few when you got it. Its over half the cylinder wall all the way up and down
Old Aug 1, 2013 | 11:21 PM
  #102
Bluelightning's Avatar
Got Bewst?
Uhhhhh actually it's all at the top. Theres some light scoring down the rest but ofcourse thats going to happen as the top of the cylinder gets worse.
What caused the scoring to get worse billy? Friction! I could hone that cylinder and hone out most of those scratches having it just as I got it from you. They aren't deep. You can't seem to wrap your head around it's only on one cylinder and only on the exhaust side. There. Was. No. Contamination.
I will put pics of the entire motor when I get a chance. Just posting that one pic you keep going back on is pointless.
Old Aug 2, 2013 | 12:22 AM
  #103
ebristol's Avatar
I knew this thread would not end well based on the first 5 words of the first post.
Originally Posted by kxrida2000
I have it laying around
Sounds like both parties have some skin in the problem. More importantly, get this engine fixed so this build can reach it's full potential.
Old Aug 2, 2013 | 07:00 AM
  #104
kxrida2000's Avatar
I thought it was 2 cylinders. Now its 1?
Old Aug 2, 2013 | 08:55 AM
  #105
Got Bewst?
Ill agree with you on that. When I received the motor and saw the light scoring the hone wouldnt take out I should have disassembled the motor and resleeved it. At that point I had blown my budget so just went on hope that Billy's machinst was right and it wouldn't cause a problem. I'm not mad that I got cylinder damage on the one. I knew the risk and chance I was taking. If I had known about the damage to the cylinders though I would have never bought the motor in the first place. The motor was actually very clean when i got it. But the cylinder issue is seperate of the motor getting tight in the bottom end. But you're right, this motor is going to get fixed properly this time and used to its full potential
1 is actually damaged from the light scoring. The other one isn't.
Old Aug 2, 2013 | 09:56 AM
  #106
574's Avatar
574
I'm betting the lower end bearing housing may have been machined so they had looser clearances? Very interesting, makes me **** bricks though
Old Aug 2, 2013 | 10:46 AM
  #107
mrbelvedere's Avatar
wtf are you talking about 574
Old Aug 2, 2013 | 10:49 AM
  #108
MP Cobalt's Avatar
Billy it still for sale I'll give you a Snickers bar for the block hahahah
Old Aug 2, 2013 | 10:50 AM
  #109
574's Avatar
574
The Easter *****
Old Aug 2, 2013 | 11:36 AM
  #110
Got Bewst?
I have the motor and that's about all it's worth right now lol
Old Aug 2, 2013 | 12:33 PM
  #111
hucks1987's Avatar
I have a few questions!!!
Why would you reuse old sleeves on a new build? I understand that you can, but depending how how many miles are on them, were they ever guaged? Like with a dial bore guage? Where the pistons sized? With the thermal expansion, if you didnt have the proer piston to wall clearances, that could cause scoring, Or if there is to much, sand/dirt can get in between the wall and piston, like sit on top of the rings.
And how was the motor stored? was it wrapped? If it sat without a head, and wasnt wrapped in srink wrap, Your kinda wrong, there is a reason why most shops wrap when while there sitting or shipped.
Iam not on either side, but reading thru here i had to ask
Old Aug 2, 2013 | 01:04 PM
  #112
Got Bewst?
I can't answer any motor build questions but I will say when I got the motor it was very clean. Even in the cylinders there was zero debris or dirt so I would say it was stored properly.
Old Aug 2, 2013 | 03:08 PM
  #113
kxrida2000's Avatar
Sleeves were checked with a dial bore gauge and were fine. Motor was assembled lubed and wrapped in a brand new garbage back. Bag was taken off 1 time to take pics for bluelightnig.
I'll never sell a motor without a head bolted on again though. I would bet my life there was some contaminate sitting on the piston and wrecked the cylinder wall
Old Aug 2, 2013 | 03:15 PM
  #114
Got Bewst?
HEATON
Oct 16, 2015 07:21 PM
c_m_shooter
Sep 27, 2015 04:40 PM
Cptnslo
Sep 24, 2015 09:32 AM
Dustin24
Sep 19, 2015 09:28 PM
09BlkCrusader
Sep 9, 2015 04:47 PM
