YOUR current LSJ setup
My LSJ Setup
Stock short block
ZZP Stg2 Cams
zzp 82# springs/Ti Retainers
Single Pass Mani w/ Phelonic Spacer
OTTP 3" Intake
OTTP LTH, Catless Cross Pipe, 3" back
OTTP H/E +Opt B
OTTP Return Style BRFS w/ Walbro 342 + Rewire
OTTP 2.6"
80# Inj
Cometic w/ ARP Studs
Driveline
Fidanza
GM Stg2 Clutch
LNF Throwout
TTR S.T.O.P. mounts
TTR Solid Upper
OTTP Stg1 Axels
LNF struts/shocks
Eibach Pro-Kit
Stock short block
ZZP Stg2 Cams
OTTP 3" Intake
OTTP H/E +Opt B
OTTP 2.6"
80# Inj
Driveline
Fidanza
GM Stg2 Clutch
LNF Throwout
TTR S.T.O.P. mounts
TTR Solid Upper
OTTP Stg1 Axels
LNF struts/shocks
Eibach Pro-Kit
Last edited by 07_Red_SS/SC; Nov 24, 2012 at 12:36 PM. Reason: Didn't know we were including driveline
2007 ss/sc stage 2 factory
gm 2.9 pulley
stage 2 belt
ottp replacement screws
TTR solid upper engine mount
zzp stage 1 axles
ky stage 2 clutch
findanza flywheel
80s
badmab header
borla exhuast
ingalls torque damper
zzp heat exchanger
zzp cai
hp tune
aem wideband
zzp dual pass endplate
eibach sportline
and some stuff for looks
gm 2.9 pulley
stage 2 belt
zzp stage 1 axles
ky stage 2 clutch
findanza flywheel
80s
badmab header
borla exhuast
zzp heat exchanger
zzp cai
hp tune
aem wideband
eibach sportline
2.8
80$
E85
Zzp s3 he
Dual pass
Opt b
Vibrant 3in h/d/e
Zzp motor mount
Ottp stage 2 mounts
Zzp strut tower bar
Powell xxx bar
Zzp 3 in intake
Act hd clutch
Bc coilovers
Interceptor gauge
Area 47 tuned
80$
E85
Zzp s3 he
Dual pass
Opt b
Vibrant 3in h/d/e
Zzp motor mount
Ottp stage 2 mounts
Zzp strut tower bar
Powell xxx bar
Zzp 3 in intake
Act hd clutch
Bc coilovers
Interceptor gauge
Area 47 tuned
under hood:
2.8
60s
zzp intake with K&N filter
option B.
Ottp fmic/ Heat exchanger haha
1 step colder plugs
Vibrant header/dp combo catted
Vibrant 3in catback with Dynomax 3in super turbo muffler
hose clamps on the exhaust hanger bushings to pull the exhaust up
and ottp stage 2 mounts
steering rack spacers
moog endlinks
ksport coilovers
5mm spacers up front
gauges (3)
2.8
60s
option B.
1 step colder plugs
moog endlinks
ksport coilovers
gauges (3)
were did you get your clutch relase kit from
TVS
2.7" pulley
Injector Dynamics 98# injectors
E85
Euthanasia ported head
ZZP 82# valve springs with retainers
Vibrant header
ZZP 3" downpipe with kooks 3" stainless resonator
Hahn 3" catback
Dual pass
Cobra H/E
ZZP phenolic spacer
GMPP Clutch
Powell Stage 1 trans mounts
ZZP stage 2 cams going in over winter.
2.7" pulley
E85
Vibrant header
Hahn 3" catback
Dual pass
Cobra H/E
ZZP phenolic spacer
GMPP Clutch
sounds like some ones got a lock down kit..
is it pressure regulated release??
