YOUR current LSJ setup
Old Dec 12, 2012 | 12:24 PM
  #301
c130aviator's Avatar
valve springs you buy should be validated with a spintron. If not, then its just a gamble, and most gambles dont work out well.
good point but I would hope ZZP did this before they ship them. Also I bought Titanium retainers but does it matter if the guy wanting to save a few bucks gets steel retainers?
Old Dec 12, 2012 | 12:41 PM
  #302
Powell Race Parts's Avatar
it costs a huge amount of money to do the spintron gig. If you dont buy major manufacturer's or OEM brands with known validation, its a risk. ZZP are very good at what they do, but I am not sure you can assume they have done this.
This should answer some of the questions, and also the issue of steel vs titanium retainers.
http://www.cpgnation.com/forum/comp-...nced-5424.html
http://www.fes-auto.com/upload/artic...ingArticle.pdf
Old Dec 12, 2012 | 12:42 PM
  #303
Staged07SS's Avatar
Administrator
Administrator
The point of titanium retainers is less valvetrain weight. They are lighter & stronger.
Lighter valvetrain components are a plus in high performance engines.
Old Dec 12, 2012 | 12:43 PM
  #304
05ssLSJT's Avatar
the titanium ones are supposed to be "lighter" thus reducing weight off the valve and allowing it to open and close easier. don't hold me to that. its what I've heard.
Old Dec 12, 2012 | 12:45 PM
  #305
Bad-A-SS's Avatar
-m62 on a 2.8 pulley
-3in intake from ZZP
-Bad-mab header to 3in ZZP downpipe to mandrel bent 3in exhaust to flowmaster muffler
-60# injectors
-ZZP S3 H/E and dual pass endplate
-ZZP Option B
-Devils Own Brew Stage 1 meth kit(3,7,10gph nozzles)
-1 step colder NGK plugs
Old Dec 12, 2012 | 12:59 PM
  #306
mrbelvedere's Avatar
when you exceed x amount of spring pressure you need to get a alot stouter retainer so it wont buckle or shove over the keepers it be lighter is just a bonus you should get a better lock also will you see a performance increase with ti retainers no you wont is it worth the money at our level of performance no i dont feel it is worth it the money could be better spent elswhere
Old Dec 12, 2012 | 01:02 PM
  #307
Staged07SS's Avatar
Administrator
Administrator
Ti retainers came with my springs so doesnt really matter for me
Also, I did mention they are stronger.... I just didn't get in to the detail you did explaining it.
Thanks though John. Always good info from u.
Old Dec 12, 2012 | 01:09 PM
  #308
Supertech make the same spring for all sorts of engines, they have been doing it for a long time, make thousands of springs over many years, and have never had any complaints of rubbing the coils on the side of the head as reported by some LNF users.... so if anyone has pictures I would be happy to see what help I can be.
The other thing that has happened however, is that there has been a running change in the rocker for the ecotec motors. I have seen this myself, as I upgraded my last GMR cylinder head; previous rockers were strained a bit (stressed) around the U shaped cup where the pivot (hydraulic lifter) sits. Early LSJ rockers were "cracked" in that area brand new.
Newer Ecotec rockers are thicker in this dimension, so if you are shopping for valve springs, I would go with the slightly softer 75 lb Supertech, which has a differently machined spring retainer, to accomodate these thicker rockers.
so order if you are interested, the SPR-TS1012/EC rather than the SPR-TS1015/EC
Valves/Springs - SuperTechPerformance.com
Now please note that I highly recommend both the valves spring with the retainer from the same manufacturer, and also that these are double valve springs. Beehive singles are brilliant technology but if they are not coming from comp cams or GM, then I would say pass, and stick with Supertechs.
all I got.
Old Dec 12, 2012 | 01:11 PM
  #309
Staged07SS's Avatar
Administrator
Administrator
all I got.
Those are the ones I went with
Old Dec 12, 2012 | 10:50 PM
  #310
When I was on the ZZP website the retainers were only like 30 bucks different or something so I went ahead and bought them figuring if I didnt someone on here would "the game" me for not buying them. LOL
mine were kind of included as well, i found a deal zzp was running on ebay with free shipping and the titaniums were included. win win
Old Dec 13, 2012 | 12:26 PM
  #311
Area47's Avatar
Rent me! per hour
if they are dual springs, you better be damn sure they have seat locators.
Old Dec 13, 2012 | 12:31 PM
  #312
Staged07SS's Avatar
Administrator
Administrator
My Supertechs came with the seat locators.
Old Dec 13, 2012 | 02:16 PM
  #313
Melon's Avatar
my new valvespring kit just arrived. i ended up goin with the 94 lb supertech setup with titanium retainers and seat locators!
Old Dec 13, 2012 | 02:21 PM
  #314
tylerjclance's Avatar
USA Y U NO HAVE AUTOBAHN?
07 SS/SC
TVS
2.7
60s
Meth
Injen Intake
Vibrant header
Vibrant 3" Catted DP
Vibrant 3" Catback exhaust
Dual Pass/Heat Exchanger
ZZP Tune
OTTP Stg2 Tran Mounts
ZZP Strut bar
D2 Racing Springs
R1 Cross/Drilled Slotted rotors
Hawk HPS pads
ZZP Stage 2 axles
KY Stg 3 Clutch w/upgrade TOB
TWM Short Throw Shifter
ZZP triple A Pillar
AEM Air/Fuel Gauge
Aeroforce Interceptor
Gen 1 Projectors with RED LED's and RED HALO's
6k Lo Beam HID KIT
12K HID Fogs
K2 LED Tail Lights with LED reverse
LED Plate, RED LED Maps, LED Sidemarkers, Red UNDERDASH LED
Old Dec 13, 2012 | 03:45 PM
  #315
574's Avatar
574
Originally Posted by tylerjclance
07 SS/SC
TVS
2.7
60s
Meth
Injen Intake
Vibrant header
ZZP Tune
ZZP Strut bar
D2 Racing Springs
Hawk HPS pads
ZZP Stage 2 axles
ZZP triple A Pillar
AEM Air/Fuel Gauge
6k Lo Beam HID KIT
12K HID Fogs
Damn your alive? you've been MIA around here!
Old Dec 13, 2012 | 07:36 PM
  #316
Curious to know why you chose 94 lb springs when Supertech recommend the 75 lb ones for the ecotec LNF... can you share? And what sort of price did you find and wheere? I have a customer just emailed me for some...
Old Dec 13, 2012 | 08:12 PM
  #317
TStone's Avatar
He has LSJ :P
http://www.turbotechracing.com/produ...idproduct=5408
Old Dec 13, 2012 | 09:33 PM
  #318
as I explained the lsj ecotec has some pretty rocky looking rockers, and while I run supertechs I have upgraded the rockers twice now... there is nothing in the tt description to persuade me differntly, and I would certainly not run a 94 lb spring in an LSJ. And I dont lol. So thats my take, it was also *****'s take at Supertech. But I was interested in the posters viewpoint; in for the learnz.
Old Dec 14, 2012 | 11:59 AM
  #319
Yeah
I've been kind of out of the loop for a while
transitioning out of the military and being poor LOL
Old Dec 14, 2012 | 01:03 PM
  #320
EXsoccer1921's Avatar
lnf rocker arms ftw!! my stock lsj's are just sitting in a box with other valvetrain parts.
Old Dec 14, 2012 | 06:59 PM
  #321
freakta's Avatar
ive seen it first hand. zzp does not do this and on multiple cars on different platforms have seen problems with zzp springs not being correct or matching
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
ThoR294
Oct 4, 2015 08:44 PM
dieGone
Oct 1, 2015 06:27 PM
