YOUR current LSJ setup
shut off the ltft's.
retune the maf with stft.
above 15 msec you're pushing the injectors.
don't flat line the timing up top.
change the pump and add bigger injectors and aim for 11.0-11.3 afr at wot
How are your intake temps on that 2.7? I cant decide between 2.7 2.8 for.meth
Do you mean shut them off permanently? Still trying to figure out my over/under idle tables, still hunts and trys to die at stop light
05.
Also what would cause it to randomly rev to 3k by itself when ata stop light?
I have done some over/under table adjustment and idle recovery after slowing to a stop light is much better. But every so often it revs by itself??
Bryan appreciate your input!
k&n cone filter in full stock intake
dual pass endplate
option b kit
2-bolt 3" exit on stock downpipe
3"x30" cherry bomb resonator
Tq managment removed
7500rpm limit
Made 215whp and 187wtq with just a RAW cai years ago.
dual pass endplate
option b kit
7500rpm limit
Yeah i that's what's i have and everything runs fine for me as well. But i have seen where others only run 80s with there e85 set up. Now if i do drop to the 2.7 then yea I'll probably get em then
Here is mine:
06 SS/SC G85 LSD Turbo Swapped
BorgWarner EFR 6758 Turbo
BYT HP Tuned
BYT 304SS Tubular Manifold w/ Merge Collector
BYT 304SS Catless Down Pipe
BYT 3' CAI
BYT "Stealth" Charge Pipes
TTR Intake Manifold
TTR Upper Engine Mount
TTR Rear Sway Bar
ZZPerformance 2.1 Forged Shortblock
ZZPerformance Front/Rear Transmission Mounts
ZZPerformance Front Strut Bar
ZZPerformance Stage 2 Race Trans 4.45 Now a 6 Speed
ZZPerformance Stage 3 Axles
ZZPerformance Stage 2 Port and Polished Head
ZZP Stage 2 Comp Cams.
ZZPerformance Triple Gauge Pod
ZZPerformance Boost Reference Fuel Pressure System Option 2
VP Racing M1 Meth 50/50 Mix
Aeromotive Stealth Fuel Pump
Mototron 80# Injectors
Hallman Pro RX Manual Boost Controller
Eibach Front Sway Bar
Exedy Stage 3 Hypersingle Clutch (2nd one)
DevilsOwn Progressive Meth Kit
N2MB Wotbox NLS/2Step
AEM Uego/Boost/EGT
Aeroforce Intercepter Scan Gauge
Modern Performance MPx Steering Column Gauge Pod
Hurst STS
HP Tuners Software
15's Verde Protocols Rims
15's M & H Slicks (Track)
18's Falken Azenis RT-615k(Street)
Pioneer AppRadio
Kicker 1000Watt Amp
Dual 12's Kicker L3 Box
Excaliber Remote Start/Alarm
At ZZP right now for some changes again. Should be a little over 500 when all done.
BYT HP Tuned
BYT 3' CAI
TTR Intake Manifold
TTR Rear Sway Bar
AEM Uego/Boost/EGT
Hurst STS
HP Tuners Software
Pioneer AppRadio
Kicker 1000Watt Amp
