YOUR current LSJ setup
Old Dec 3, 2012 | 06:25 AM
  #251
06cobalt racer's Avatar
06 ss/sc
stock blower with a 2.8
airbox mod with AEM filter
60# injectors
zzp shorty header
3"-2.5" downpipe with hi flow cat
magnaflow 2.5" catback
50/50 meth injection with 8GPH nozzle spraying pre-blower
dual pass endplate
flow-thru tank
zzp s3 he inline with stock he
1 step colder plugs
trifecta tuned
soon to be added: phenolic spacer
i have more mods but those are my engine mods
Old Dec 3, 2012 | 08:39 AM
  #252
ULWizSS's Avatar
hows everything coming along there. i know its been a while
I was MIA for a while so they pulled it back out and stopped working on it. THey just got the go to continue again so it should not be much longer. Its pretty much ready to be slapped in so waiting on tim to get back to me if you were asking me.
Old Dec 3, 2012 | 02:37 PM
  #253
EXsoccer1921's Avatar
ahh okay. yeah i hadn't heard you on the forums at all lately
Old Dec 3, 2012 | 03:51 PM
  #254
Area47's Avatar
Rent me! per hour
Originally Posted by JapEatr
05.
Also what would cause it to randomly rev to 3k by itself when ata stop light?
I have done some over/under table adjustment and idle recovery after slowing to a stop light is much better. But every so often it revs by itself??
Bryan appreciate your input!
if i had 05's unlocked, id just fix it for you.
Old Dec 3, 2012 | 07:43 PM
  #255
Powell Race Parts's Avatar
your passport still good? April or may sounds like a good time to travel lol
Old Dec 4, 2012 | 12:35 AM
  #256
JapEatr's Avatar
South Central *********
PM me your email Bryan, ill send my file over, youncould at least look at it without licensing
Trying to work out some of the little driveability tweaks before the 1000s are ordered
Old Dec 4, 2012 | 12:51 AM
  #257
chris88z24's Avatar
Just placed a car chemistry 3 disc insert in my ZZP 2.5" catted downpipe. The car sounds SO GOOD, it's quiet and has power to silently blow by people in traffic.
Best of all, the rasp is completely gone and the car sounds stock. The supercharger sounds downright nasty too even with the stock intake
Best LSJ mod by FAR.
Old Dec 4, 2012 | 12:55 AM
  #258
JapEatr's Avatar
I had an exhaust auger that sounded good but ended up rattling too much
Old Dec 4, 2012 | 12:56 AM
  #259
chris88z24's Avatar
this one doesnt rattle. its perfect i actually enjoy driving the car again
Old Dec 4, 2012 | 01:17 AM
  #260
RooTBeeR's Avatar
for teh lulz
These should be really close to the actual numbers.
Stock Tune with Torque Management Removed and 7500RPM Limit
vs.
Stock Tune with Full Torque Management and 7500RPM Limit(~3psi)
Mods
Full Stock Intake with a K&N Cone Filter
3" Flange on Stock Downpipe
3" x 30" Resonator
~5850RPM and up, stock injectors go static on the stock PE & MAF tables
Old Dec 4, 2012 | 01:22 AM
  #261
chris88z24's Avatar
Mine made 220whp/180wtq with the stock pulley/injectors/intake/exhaust after a tune. I think all I did was raise the rev limiter to 7k and get rid of the spark retard when shifting and also ditched the tq management bs
Old Dec 4, 2012 | 11:48 AM
  #262
Area47's Avatar
Rent me! per hour
i have to find it, but i think it's still good.
i can do that.
Old Dec 5, 2012 | 11:01 PM
  #263
JapEatr's Avatar
Bryan, sent you an email. Let me know if you see anything whacky.
Trying to learn this driveability tuning a bit better
Also trying to get a feel if i should put stock heat range plugs in, or keep the 7 heat range in there
Old Dec 5, 2012 | 11:14 PM
  #264
brk7eix or whatever. at 375 stock wont do it.
Old Dec 5, 2012 | 11:22 PM
  #265
bkr7e?
the ix are the bkr6eix iridiums. idk if theres a 7eix. could be
Old Dec 5, 2012 | 11:39 PM
  #266
JapEatr's Avatar
Bkr7e are what is in there now
Ive heard stock heat range can help with cold starts on e85
Old Dec 6, 2012 | 12:29 AM
  #267
JapEatr's Avatar
Debating on returning these stock plugs
Old Dec 6, 2012 | 01:46 AM
  #268
InfraRedline's Avatar
I run the Bkr7e on mine. Havent tried the stock ones, but Ive always had good luck with the 7's gapped at .032
Old Dec 6, 2012 | 02:02 AM
  #269
idk about e85. but 7e's haven't let me down once
Old Dec 6, 2012 | 12:04 PM
  #270
Area47's Avatar
Rent me! per hour
bkr7e gapped to .027
depending on dwell settings.
Old Dec 6, 2012 | 01:02 PM
  #271
chris88z24's Avatar
bkr7e?
There is, I have them in my whip.
Old Dec 6, 2012 | 05:45 PM
  #272
Lol me too! We dont make this S**T up. and I have posted the entire ectotec spark plug information way too many times.
Old Dec 7, 2012 | 04:01 AM
  #273
did you weld it in? or use a bolt to hold it?
Old Dec 7, 2012 | 01:04 PM
  #274
I have used super trap discs on exhausts I found them not very effective for noise control but very effective for killing power...my .02 c
Old Dec 7, 2012 | 01:25 PM
  #275
chris88z24's Avatar
I'm going to tack weld it once I switch to the snow tires. I used cold weld to hold it in place but as a fail safe the insert is 2.5" and the inlet to the stock resonator is smaller so it's not going anywhere anytime soon.
I'd go with the weld because with the salt up here a bolt will eventually rust and cause moar leakz.
John this car chemistry insert is awesome. I don't feel any power loss, in fact the car feels faster and I can now pass the majority of cars on the road without having to floor it. lol
